Question about Kitchen Ranges
How to light the pilot light? Please help! Thank you
  • kakima Dec 19, 2016
    Hi Stephanie Baker, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Pilot light on what make and model?
My Magic Chef oven is getting soot all over the inside of the oven and the pan is warped on the bottom of the oven
Hello, Thank You for using FixYa. I will be helping you today.Your pilot light is set way too high! You need to correct this and you should clean the pilot area also before turning the unit back on.
Thank You and please rate my answer if it was helpful..
Jun 25, 2011 | Magic Chef 31001 Gas Kitchen Range
I need to light the pilot on the oven. please help me!!
Hello, Thank You for using FixYa. I will be helping you today.You can light it by removing or opening the drawer, Hold or push in on the oven knob and hold it in while you light the pilot,Keep holding it in untill the pilot wont go out.
Jun 23, 2011 | Magic Chef CPR1100AD Gas Kitchen Range
How to I relight the pilot of the burners on my kenmore 362.72201891 oven. Not the oven pilot but the burner pilot light.
Hello, Thank You for using FixYa. I will be helping you today.There are no standing pilots to light.
Jun 17, 2011 | Kenmore Ovens
Pilot light has gone out we have no hot water how do we relight it the auto relight isnt working either
Hello, Thank You for using FixYa. I will be helping you today.Set the knob to pilot and push in on the knob and hold it in then push the ignitor button while still holding in the knob when it lights keep holding in the knob after a few seconds let go of the knob if the pilot stays on turn the setting to on.
Jun 10, 2011 | Kitchen Ranges
Trying to light pilot not sure where to light at hear gas come on n not sure how to or where to light
Follow the 1/4 inch aluminum line from the thermostat. It feeds the pilot. Please rate my response to your question. I am new to this site and need to improve on how I relay the information. Good or bad is OK. It all helps. Thank you for writing FixYa! Roger
Apr 05, 2011 | Heating & Cooling
Can we relight the pilot manually or do we need an electronic lighter? Ours appears to have gone out. Also please verify that what we're looking at IS the pilot light! Thank you!
if it is a permant pilot then you can light it manually , if is a hot surface ignitor then you will have to replace it , some electronic ignition has to be replaced , as it self lights .
Hope this helps you
Nov 30, 2010 | Coleman Propane Forced Air Heater...
Can i get a new pilot light assembly for a vulcan cx 90 ducted heater
If you can not,do this,take a piece of 3/16 tubing,and cut it to fit over the pilot light,and make sure the tubing is cut long enough to extend into the flame of the pilot light,this will save you money,and time,most of the time the problem with the pilot light is,that it burns away over time,and does not stay into the flame .If this was helpful,please rate,thank you.
Jul 14, 2010 | Heating & Cooling
Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Jun 15, 2010 | Heating & Cooling
I have Dayton space heater 3E 229, pilot wont stay on,I have install new gas operating valve and checked transformer ( 30V) . Pilot lights up but wont stay on even if I hold button down for 2-3 min. please...
The thermocouple is likely defective...(Copper wire heated by the pilot) or the pilot itself is too small or dirty....the pilot must be BLUE , not yellow like a candle...and it must envelop the top portion of the could also have an auxiliary limit or ECO wired in series with the thermocouple circuit that could be open.....also make sure the thermocouple is inserted all the way and is in the pilot flame as mentioned above
Oct 25, 2009 | Dayton Gas Furnace Heater
two options.first does the pilot flame look good (a nice blue flame)?if so you will see a metal probe next to the pilot,use some sandpaper and clean that probe up.if that solves your problem so be it.second if the first thing doesnt work its probably the ignitor board not sensing the flame.the way to definitly tell the one or the other use a small torch and heat up the probe like i said and turn the oven on.if the main burner comes on then you know its the probe which is called a thermocouple and is cheap.hope this helps.
Aug 08, 2007 | GE JGBC20 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
