Question about Health & Beauty
I want to order 37LiB1 toothbrush heads for electric toothbrush
Where can I find a replacement bulb for my pursonic toothbrush?
Fixya is unable to identify sources for Personic parts.
Mar 19, 2018 | Health & Beauty
I ordered a Soniccare Diamond Clean Smart toothbrush on Jan. &, 2018. Have not receive a tracking # or or the toothbrush I ordered. I would like an update.
Hello, Melita -
If you are thinking you ordered the toothbrush from Fixya.com, you did not. Fixya.com does not sell _anything_.
You will need to remember where (from what website) you ordered the toothbrush, log into your customer account, and check the status of your order.
Jan 20, 2018 | Diamond Computers & Internet
Do electric toothbrushes require a different amount of toothpaste compared than manual toothbrushes?
No, you should put the same amount of toothpaste on all types of toothbrushes. You should put enough so you can clean your teeth well.
Feb 12, 2013 | Health & Beauty
What are the advantages of manual toothbrushes over electric toothbrushes?
The main advantage of manual toothbrushes is the cost. They are much cheaper than electric toothbrushes. Whereas an electric toothbrush can cost you $50-$100, manual toothbrushes can be bought for just a few bucks. Another advantage is that manual toothbrushes come in different sizes and colors, so there's a larger variety to choose from.
Feb 04, 2013 | Health & Beauty
What can I do to make sure my toothbrush stays clean?
In order to keep your toothbrush clean and germ free, you should do the following:
Rinse the toothbrush thoroughly after every use and make sure there's no toothpaste left.
When not in use, make sure that the toothbrush is away from other toothbrush or any other tools that could have germs on them.
Make sure that the head of the toothbrush is not covered because then it would get warmer, which will promote bacteria growth.
What are the best electric toothbrushes available?
The best electric toothbrushes are the Oral-b Professional Care and the Phillip Sonicare Diamond Clean. You can find more information on these electric toothbrushes on their respected websites: http://www.usa.philips.com/c/diamondclean/289711/cat/en/ and http://www.oralb.com/products/professional-care-smart-series-4000/.
What are the disadvantages of electric toothbrushes?
The main downside of electric toothbrushes has to be their cost! They are much more expensive than the manual toothbrushes and typically cost between $50 and $70. In addition, the heads of the electric toothbrushes must be replaced every three months, adding to the cost.
What are the advantages of electric toothbrushes?
Electric toothbrushes are an excellent tool to keep your teeth clean and healthy. They offer many advantages:
They allow you to remove plaque more efficiently and quicker than manual toothbrushes.
You don't need to brush hard in order to get good results. This means that you are much less likely to injure your gums.
People who suffer from physical conditions like arthritis find electric toothbrushes as a great replacement to manual toothbrushes because they are easier to grip and you don't need to use as much physical power to get your teeth cleaned (the powered brushes do the cleaning).
It is more fun to brush with electric toothbrushes compared to manual toothbrushes, especially for children.
How often should I replace the head of my electric toothbrush?
According to the Oral-B website, you should replace the head of your electric toothbrush every 3 months. There are exceptions though. For example, if you suffer from gum problems, then you should replace your toothbrush head every 4-6 months. On the other hand, if you have very healthy gums and teeth and you are using a high quality electric toothbrush, you can probably use it for few extra months (around 6 months).
Jan 10, 2013 | Health & Beauty
What are the different types of toothbrushes?
There are three types of toothbrushes that are commonly used:
  1. 1. Manual toothbrush
  2. 2. Rechargeable electric toothbrush
  3. 3. Battery power toothbrush
For more detailed information on these toothbrushes, check out Oral-B website
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
