Question about Plumbing
My p 150.1 whasher do not pump soap. - Plumbing
My soap dispenser wont pump soap
Are you out of soap? Does the pump go freely up and down? If the pump goes down a little and then stops its probably clogged. If this is the case just get a long piece of notebook wire and slide it through the pump and it may unclog it. Really a soap pump is a very simple set-up. Suction from one end brings the soap through the tube and out the actual dispenser. Hope this was helpful:)
Sep 20, 2012 | Grohe Soap Dispenser for Kitchen...
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
The soap dispenser on my price pfister kitchen faucet won't pump soap. It pumps, but no soap comes out.
Two things spell trouble for these poorly engineered units:water and thick soap...
Inside these pumps is a metal ball for
the check valve. any water in your soap
will corrode this ball, causing the pump
to lose it's prime...
Using soap thats too thick (like Dawn)
will cause the soap to harden around the moving parts and impede the pumping
action. Try a thinner soap, such as inexpensive pink hand soap.DO NOT
ADD WATER! (See above)
Hope this helps.
Dec 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Soap dispenser pump not working
I have the same problem after just about 6 months of use. I have checked to make sure it's full of soap, before you ask...I've run hot water through it while pumping and had success in pumping just water out. Then when back in the soap, nothing happens. Soap comes up about half way into the tube and sits. I now use it as a soap dispenser, dip stick style.
Nov 29, 2009 | Moen 3910S Sand Line Art Deck Mounted Soap...
What kind of oil do i use in pump for devilbiss exwgc3240-1 pressure whasher
Dear jim_5,
Most domestic pressure washers use normal multi-grade engine oil. 15/50 wil be good. Industrial and high pressure washers usualy use gear oil (90 sae).
Apr 11, 2009 | Honda Garden
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 | Plumbing
My maytag digital whasher machine stops when is ready to spin
My mah6700aww would get to 9 minutes then stop, water would not evacuate. I took the exhaust pump/motor apart and found a piece of plastic (foreign debris) in the impeller; remove the obstruction and re-installed the pump/motor; problem solved. Three bolts that hold the pump/motor in place are 12mm. Also, important to mark the top of the plastic female electrical power connection since it is possible to reverse the connection. I saved $350 min. if you do need to replace the pump/motor they cost about $150 at an appliance parts store.
Good luck,
Dec 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Plumbing Logo
79 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
