Question about Refrigerators
The freezer setting. im assuming the two snow flakes means colder?
4 Suggested Answers
  • 10865 Answers
SOURCE: freezer too cold
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on May 24, 2009
  • 41 Answers
SOURCE: it makes snow flakes. freezer door will not seal
These snowflakes that you mention are formed by moisture entering the freezer compartment,Even if the seal appears to be doing the job just the fact that you mention "snowflakes" tells me that the seal is not doing it's job.Replace the door gasket and that should fix the problem.
Posted on Sep 21, 2009
heatman101
  • 43501 Answers
SOURCE: I need to make the refrigerator warmer. It has an
Turn it to a lower number to make it warmer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Dec 27, 2010
What does the blue snow flake mean on the display
If the power /freezer is set the blue snow flake remains lit.
How do use the digital control panel on my Samsung fridge freezer
to turn off for normal operation and power save push and hold power/freezer button for 3 seconds.
Dec 23, 2015 | Samsung RF217ACPN - 20 cu. ft. French Door...
What does the blue snow flake symbol mean on the display
A blue snow flake normally indicates cooling mode
Dec 23, 2015 | Heating & Cooling
Its set at 77 im trying to set it at 75 but the snow flake keeps flashing and the set button keeps flashing aswell
that means that it's at that now leave it be and it should slowly go down
Hope I could help (")>
Sep 16, 2013 | Heating & Cooling
Refigerator and freezer all of the sudden don't seem to keep cold enough
The back wall of your freezer covered with snow? If it is I would suggest you replace the heater and a thermistor - Heater: WR51X10101 Thermistor: WR55X10025. If no snow then it is probably the main pcb: WR55X10656
Mar 24, 2013 | GE GSH22JFT Side by Side Refrigerator
I need to make the refrigerator warmer. It has an Amana Temp Assure numbered 1 through 6 with a snow flake near the 6. Is 1 colder or is 6 colder?
heatman101
Dec 18, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Have a light which looks a snow flake which comes on and off on the dashboard. The car is a Jaguar X-Type Help!
the snow flake means the gear box is going in and out of winter mode my dad had the same thing happen but on a diffrent car he topped up his gear box oil and it was fine after
Nov 08, 2010 | Jaguar X-Type Cars & Trucks
My quickchill 420 cc elite whirlpool refrigerator's lower compartment is not cooling at all whereas the freezer compartment is functioning properly. I am in Panchkula near Chandigarh. tel No 8872119703. Pl...
Set both controls to middle setting, pegging the stat is ok , pegging the colder/warmer to colder ,akes the freezer colder, not the reefer box. colder means colder freezer, it does this by starving reefer box of airflow.
Nov 01, 2010 | Refrigerators
Woods freezer yellow light looks light a snow flake wondering what that means
Does it sound like it is never shutting off/ It may mean it is over freezing. Also for good measure >>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 01, 2010 | Woods 4.3 cu. ft. / 122 liter Chest...
It makes snow flakes. freezer door will not seal
Sep 20, 2009 | Refrigerators
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
