Question about Canon Office Equipment & Supplies
I changed Black ink cartridge and tried to print .Alaram light up U161 Error is displayed give me solution ?
My Printer is Canon Pixma MX 340 Model
old marine
  • 2105 Answers
SOURCE: giving the error e 2,3
Go to this link. Type "error e 2 3" in the search window and click the Search button. Try the troubleshooting steps provided. If the error still persists, you may need to have the machine serviced.
Posted on Apr 30, 2008
efs_perpends
  • 1996 Answers
SOURCE: how to change ink jet cartridge canon 'pixma' printer mp160
Please go to this Canon link (click here) and enter the term "ink cartridge replacement" in the search window for a set of detailed instructions (with pictures) on how to replace your ink cartridges.
As you face the printer, with the scan cover open,in position to remove them, the black cartridge goes on your left and the color on the right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 09, 2009
ikechinedu
  • 184 Answers
SOURCE: Canon PIXMA MP190 'not responding'
There are possible causes of this not responding status message you get. you will try out these option i have listed here and see which one resolves the problem. after each one, try to print from a file and from the web.
1. Configure driver to correct printer port
On the 'Ports' tab of 'Printer Properties' window, select the correct port for the printer driver.
From the Windows desktop, open the printer's properties window.
Click the Ports tab.
Below 'Print to the following port(s)' section, select the port to which your printer is connected.
Click 'Apply' to accept the changes.
Click General tab and then click 'Print Test Page' to confirm the changes corrected the issue.
2. Checking USB Connections
You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, try connecting the USB cable directly into the computer.
Repeat step one to reseat the cable on the other end.
3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
when you are through, restart the system.
4. Uninstall and Reinstall the Driver
If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.
Caution: Uninstalling means deleting software, such as MP drivers, from the computer. Once the software has been deleted the unit cannot be used through the computer until the software has been reinstalled.
Note: Login as a user with Administrator privileges to uninstall . Turn off any programs running in the background, such as antivirus programs and firewalls before begining.
Select 'Program' (for Windows 2000), or 'All Programs' (for Windows XP / Vista) from the Start menu.
Select the name of the printer model to remove and select 'Uninstall.'
When the MP Drivers Uninstaller window is displayed, click 'Perform.'
When the confirmation window is displayed, click 'Yes.'
When the Uninstallation Complete window is displayed, click 'Complete.'
5. Reinstall the Drivers
Note:
The MP drivers can be installed using Easy Install or Custom Install.
Easy Install automatically installs the software which is in the CD-ROM.
This method is recommended if you are a first-time user.
Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
Login as a user with Administrator privileges to install on WindowsXP/Vista/2000.
Close any antivirus software that may be running prior to installing the drivers.
Turn off the printer and disconnect the cable connecting the computer and the printer.
Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
If the setup program does not start automatically, click 'Start' and go to 'My Computer', then double-click the CD-ROM icon.
If you use Windows Vista, select 'Computer' from the Start menu, then double-click the icon of the CD-ROM.
At the main installation window, click 'Easy Install' or 'Custom Install'.
When selecting Easy Install:
(A) Click 'Easy Install'.
(B) Click 'Install' in the following window.
* Display varies according to the printer model.
When selecting Custom Install:
(A) Click 'Custom Install'.
(B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
When the License Agreement window is displayed, read the content carefully and click 'Yes'.
The installation will start.
Messages may be displayed during the installation of the application software.
Follow the instructions on the window and continue the installation.
When the Printer Connection window appears, connect the printer to the computer and power on the printer.
Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
3) Restart the computer.
4) Install the printer driver again.
For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
At the Print Head Alignment window, click 'Execute'.
Note:
* The Execute button may not appear for all models. In that case, skip to step 13.
* The Print Head Alignment can also be done after the installation of the printer driver.
When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
At the Do not start another operation until current one has finished dialog box, click 'OK'.
When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
At the Installation Results dialog box, check the content then click 'Next'.
The installation of the MP drivers and application has completed. Proceed to the Canon user registration.
If you want to register now, click 'Register'. If not, click 'Next'.
Registration can be done after the MP drivers installation.
Then, Inkjet Extended Survey Program will be launched. If you agree, click 'Agree'. If you do not agree, click 'Do not agree'.
At the Installation completed successfully dialog box, click 'Exit'.
Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Posted on May 22, 2009
daryn720
  • 113 Answers
SOURCE: black ink cartridge is leaking and black line is running down back of page
YOU CAN TRY PULLING THE CARTRIDGE OUT AND WITH A CLEAN , VERY SOFT CLOTH , CLEAN THE HEAD GENTLY ....SOME CARTRIDGES ARE JUST FAULTY ....HAVE YOU TRIED RETURNING IT OR GOING TO CANON SITE AND TROUBLESHOOTING ?
Posted on Jun 02, 2009
Sak-en na
SOURCE: How do you reset ink levels on a Canon pixma mp190 printer?
you can reset low ink error by pressing stop/reset button for 10 seconds
Posted on Oct 27, 2009
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
How to set ink level on canon mx-320 after refill?
Apparently the problem is that you are choosing to install (according to Canon), cheap, aftermarket ink cartridges rather than Canon ones. Therefore the machine is not recognizing them. Try this procedure, found on another forum, that was supplied by one of the cheapo ink companies. Who better to know how to fool the machines than them. If they want to sell these ink carts, they better know who to make them work!
U051 Error Correction procedure.
1- Switch off the Canon MX300 and disconnect the power cable.
2- While press and hold the power button, Connect the power cable to electric socket.
3- While pressing the power button, press the "Cancel/Stop" button (red button). (press TWICE che "stop\cancel" button)
4- Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".
5- Press ">" (next button) once "Shipping Mode 3? then Press the "OK" button. Press "OK" again for "without cleaning". A test page will print.
6- Open the cover, like you are about to change the cartridges.
7- Disconnect the power cable again without switch off the printer.
8- Take out the both cartridges.
9- Close the cover.
10- Connect the power cable and turn on the printer.
11- Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Jan 14, 2015 | Canon Black Pixma Mx 320 High Quality...
HOW DO I CHANGE THE INK CARTRIGE IN MY CANON 340 PRINTER?
Carefully take out the ink cartridge from the printer. Make sure that you unplugged the printer. Do not touch any electrical wiring. Attach the new ink cartridge. A distinct click will confirm that you reinstalled it properly. Do not expose the cartridge to heat or light for more than 10 minutes to prevent damage. And run a test print.
Dec 12, 2012 | Canon PIXMA iP4000 InkJet Photo Printer
I have a Canon MX 340 printer. I have installed a brand new Canon 211 XL color cartridge, which I believe is compatible with this unit. Whenever I go to print something in color, I am getting the...
Click on Printer & Faxes in the Control panel. Right click on your printer icon. On the drop down menu click on properties. You will see many Tabs relating to your Printer. One of them will be Maintenance Tab Click on it and on the page which opens do the needful.
Jan 20, 2011 | Canon Office Equipment & Supplies
Canon Pixma MP160 "Head ID Error" when try to print.
E5 is "The ink cartridges is not install or a non supported ink"
Probably one from your cartridges is defective.Replace the cartridges.
Sep 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MP150 - Error code E7, light C flashing
Try removing cartridges and manually claening the heads with cleaning solution and cotton bud (q-tip) replace. Print. No luck? Now try uninstalling and reinstalling printer.
Mar 13, 2007 | Canon PIXMA MP150 All-In-One InkJet...
24 people viewed this question
old marine
old marine
