Question about Frigidaire Kitchen Ranges
What wrong with my Frigidaire range # FEFL77ASG it burned my banana bread 45 minutes into cooking and was not done in the middle .I noticed the broiler element on
catriver
  • 878 Answers
SOURCE: oven is cooking unevenly
ladder, here are some suggestions to try to help you with this problem. Make sure that you wait another 10 minutes to put your food in after the preheat light goes out or tone goes on. The manufactures like to get that energy effecient label on these ranges. If your utensil is dark, darkened by age or glass, these will absorb more heat and can cause over browning. Lower the oven temp for these types of utensils or use a pan with a shiney finish. Make sure the utensil is not too close to any oven wall. Do not check for doneness until minimum recommended baking time. Opening the door frequently causes the lower element to cycle and provides too much intense heat. Use the second or third rack from the bottom. Finally, check the owners manual for calibration instructions. You might be off with that. Catriver...post back.
Posted on Dec 18, 2006
MNTECH
  • 1543 Answers
SOURCE: cooking element
You do not list a full model number. Typically a JBP78_____ uses a WB44X10013 bake element. Disconnect power to range. Take out two 1/4 inch hex head screws holding element in at back of oven. Pull element out a few inches into oven. Disconnect wires. Reverse to install. Not too hard if it is an exposed element. A bit more involved on ranges with "hidden" bake elements (which are under the floor of the oven).
Posted on Oct 11, 2008
SOURCE: electric range broiler element popped and burnt
Did you replace burnt fuse/tripped breaker?
Posted on Apr 09, 2009
garing
  • 998 Answers
SOURCE: Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Posted on Aug 22, 2009
  • 530 Answers
SOURCE: Broiler turning on-Kenmore Electric Range Model# 66595781000
i would say you have a bad board
Posted on Sep 15, 2009
My banana bread is cooked on the inside and delicious but the outside burned slightly. How can I salvage the bread and still have a dessert?
Make a custard or use a pudding mix, and cut off the burnt outside, Add some sprinkle and or a dollop of cream, or ice cream.
Dec 09, 2017 | The Kitchen Appliances - Others
When I make banana nut bread, it always falls in the middle, do I need more flour or baking time?
If you are making it in a bread maker, it's the blades that do that. Better off just mixing the ingredients then putting it in a pan in your oven.
Oct 12, 2014 | Kitchen Appliances - Others
Im looking for a receipe for bannana bread
Make Delicious Homemade Banana Bread
Cooking your own banana bread from home is a relatively straightforward thing to do, although it does require a couple of moderately advanced techniques such as creaming butter by hand and folding ingredients together.
BBC Food states that you can prepare your banana bread in under 30 minutes, while cooking time lasts between 30 minutes to an hour in order to produce a delicious loaf of homemade banana bread.
Preheat the oven to 350 F.
Sift your flour, bicarbonate of soda and salt through a sieve and into one of the two mixing bowls, ensuring that you eliminate all clumps and are left with a fine powder in the bowl.
Allow your butter to reach room temperature before creaming the butter and sugar together in the other mixing bowl.
Swirl the wooden spoon in a circular motion to beat the butter and sugar into one another for at least a minute.
The creaming process is finished once you are left with a light and fluffy, even mixture.
Crack open both eggs and add them into the creamed butter and sugar.
Peel all four bananas and lay them flat on a chopping board before mashing them into a pulp using the potato masher.
Add the mashed banana into the mixing bowl along with the buttermilk and vanilla.
Mix these ingredients together using the wooden spoon before adding the flour, bicarbonate of soda and salt from the other mixing bowl.
Fold the contents of the bowl using the large metal spoon.
Many chefs use a figure of eight movement, cutting through the surface of the liquid with the leading edge of the spoon remember that the objective is to keep a much air in the mixture as possible, so you should look to turn over the spoon as you complete figure of eight motions, thus replicating a folding motion.
Grease the loaf tin using a small amount of butter or oil, as this will prevent your banana bread from sticking to the tin after you have baked it.
Pour in the ingredients from the mixing bowl, taking care not to spill any or make a mess.
Wait for the liquid to level off so you have a flat, even surface and insert into the oven to bake for approximately 1 hour.
Remove your banana bread from the oven when it has risen and turned a golden brown color. Allow the bread to cool in the tin for 2 minutes before turning it out onto a wire rack and allowing to stand until cool.
Aug 12, 2013 | Computers & Internet
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Done outside gummy inside
Hi.
I'm guessing that this is a cooking problem, so here goes.
If the food your cooking is done on the outside, but not done on the inside, then you have the temperature at the wrong settings.
Reduce to a lower temp, try with a new batch, and cook it for 50% longer at the lower temp: i.e. if it said 350 degrees for 30 minutes, then reduce to 300 and cook it for 45 minutes instead.
The longer time allows for the heat to penetrate and cook the middle, not just the outside.
I hope this helps you out, and good luck.
Mar 14, 2011 | Computers & Internet
Had bread burn and small fire F-10 flashing...how
Hi.
This is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor ASAP.
Feb 21, 2011 | Frigidaire FGF316 Gas Kitchen Range
Toastmaster bread box-What number should I cook banana bread with baking powder and soda? Model 1154 I don't have the manual. I used recipe from magic chef manual--banana bread-quick bread
Here's a link with the model's recipe book.
Good luck on your next batch (assuming you already baked the one from early in the month-lol).
http://kitchen.manualsonline.com/mdownloads/1e71dde0-c2a7-4eef-b260-28275af1aeb2.pdf
Jan 02, 2010 | Toastmaster Kitchen Appliances - Others
I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
When baking bread in my Kenmore electric range (9435) the loaves on the bottom rack burn on the bottom and the ones on the higher rack take almost 2X as long to cook
In an electric range, the ideal place for baking is the middle shelf. there are temperature differences within the oven cavity. On the bottom shelf the heating elements actually "broil" the bottom of the pan. In the upper part of the oven, the temperature is lower, being blocked by the lower pans. A convection style oven is more ideal for bread baking.
Aug 23, 2009 | Kitchen Ranges
Oven is cooking unevenly
Dec 17, 2006 | Roper FEP310 Electric Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
