Question about Tricity Bendix Dryers
My tricity bendix tumble TM 545 works but wont heat
2 Suggested Answers
  • 197 Answers
SOURCE: tumble dryer running but not heating up
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
Posted on Nov 09, 2009
Tricity bendix tm 550 motor spring adjustment
If there is no provision for adjustment, the spring may have lost its tension and will have to be replaced.
Nov 18, 2016 | Tricity Bendix Dryers
Tricity Bendix tumble dryer TM 560 will not Heating but drum is rotating.
Hi, it could be the heating element needs to be replaced, best get it checked.
Apr 05, 2016 | Tricity Bendix Dryers
My tricity bendix dryer TM 320W is heating up but it's takeing at least 3 full cycles to dry the clothes and the water tank is hardly ever full, whereas i had to empty it after ever few loads before. any...
check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
Aug 04, 2010 | Tricity Bendix TM310W Electric Dryer
Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Jan 30, 2010 | Tricity Bendix TM310W Electric Dryer
Tumble dryer running but not heating up its a tricity bendix tm 545
Nov 09, 2009 | Tricity Bendix TM310W Electric Dryer
Tumble dryer spins, but doesn't heat up
You need an ohm meter to do needed checks. Unplug dryer from power,,, then look for sensors and locate the heat coils. Using the ohm meter, check each device by connecting meter to the posts ( your looking for an open curcuit) Note that when you touch the leads of the ohm meter together, the gage will move? This is closed condition, and if the needle did not move, this is called "open". When you find a sensor or heat coil that reads open, that part is bad.
Now make sure there is not a tripped breaker in the fuse panel of the house,,, because even though the dryer is 220 volt,,, 110 volt runs the tumble motor while the other 110 volt curcuit runs the heat side ( so one will work without the other)
Oct 10, 2009 | Tricity Bendix TM310W Electric Dryer
Dryer shorts out some of the electrics when its switched on!
The breaker in your breaker box is either weak and need to be replaced or the amps is too low. But from what you stated, you have had this dryer for awhile, so I'm assuming that its just a bad breaker. If the dryer still runs and doesn't have any issues when it dosn't pop the breaker, then this is what it is. Have an electrician come out and replace the breaker if you are not familiar with doing this.
Apr 10, 2009 | Tricity Bendix TM310W Electric Dryer
Tricity Bendix tumble dryer Tm540
More likely to be heater element failure, you need to test element and or stat(s) with a meter.
Plz rate this solution
Dec 14, 2008 | Tricity Bendix AW1054 Front Load Washer
TUMBLE DRYER
Hi, It wont fill up when the full tank light is on because it thinks the tank is full. Remove the tank and feel down inside where the tank sits into the machine. You should feel the switch, it sounds like it is stuck down.
Jan 03, 2008 | Tricity Bendix AW1400W Front Load Washer
Dryers Logo
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
