Howe to set palsonictf151 tv withone for all controla ken.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Feb 04, 2017 | Televison & Video
Only audio video is not shown, is the child looked using the remote, use password ? howe to solve it?10Q the brand is SONY. the colour is black
It is not with child lock. sounds like the input selector IC is faulty. Contact the authorized service centre for Sony. Electro help
Jun 22, 2014 | Televison & Video
Serial numbers winchester: bolt action #39163A, barreled by Griffith & Howe.
Griffin and Howe were out of business before the 300 win mag was introduced.
Sep 24, 2013 | Remington Model 700 BDL LSS Bolt Action...
Howe to fix a 2004 kia sedona a/c blower that doesn't work?
Could be the blower motor, resistor, fan switch, or fuse.
Jun 28, 2012 | 2004 Kia Sedona
I set remote on "cool"
Hi there, this is a 21/2 ton split system. You can lower it to 68 degrees, but I wouldn't go any lower then that.Auto is for the fan only, it cycles on and off in the auto position, and in the on setting it runs all the time even when the cooling stops just to circulate the air. You can try and leave it in the on not auto as this may help the room stay cooler. Please keep me posted.
A/C, Contractor.
PS, if the remote does not say on, and just says auto and cool, set it to auto.
Jun 09, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
My remote controller of the split type machine have two keys such as 'TOO COOL ' AND 'TOO WARM' . May I get the information about functioning of these keys in which situation use .
If you press Too Warm, temp will automatically 3 degree goes down as setting temp. and same when you press Too Cool, set temp will raise + 3degree.
In your remote set temp is 24 and you press Too Warm, set temp becomes 21 and same in Too Cool will become 27. It's normally in O'General a/c May be 2 differ in other units instead of 3degree. Thanks, and helpful?
Jan 21, 2011 | Heating & Cooling
Howe should i do tu start the learning of the code at an EMW100 D dimmer
Hold down the learning button for 5 seconds until the diode starts to blink, then hold down one of the off buttons on the remote until it stops to blink. If that doesn't work then just throw it out. They're extremely cheap and low quality and they break all the time.
Sep 12, 2010 | Kitchen Ranges
Air not cold...model MSH-18NV no operating manual for remote . Not sure how to set to cool air when remote reads "I feel..." choices are cool dry or warm but when set on cool 20degrees, luke-warm air blows...
Hi FixYa team. After about 2 hours on the internet I managed to find a PDF file of the operating manual for my air con.
Thankyou for your prompt response. I'll be using your services again!
Jan 11, 2010 | Mitsubishi Heating & Cooling
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Aug 09, 2008 | Zenith R56W36 56" Rear Projection...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
