Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
U 162 Fault message while try to print .my printer is CanonPixma MX 340?
3 Suggested Answers
SOURCE: on my Cannon PIXMA MX
Problem in re- fill cartridges canon mp250 pixma
Posted on Jun 25, 2011
atsonev
  • 39 Answers
SOURCE: CANONPIXMA /THE PRINTER DOSE NOT
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the cartridges are clogged with ink, so no ink can go down to the paper and that's why you see a blank sheet of paper. The other option is that you think you have ink in the cartridges but in fact it was finished. I suggest you to replace the cartridges. Hope this helps Alex
Posted on Sep 12, 2011
My printer has a problem picking up the paper and moving through the rollers in the back.
Paper does not feed
into the machine.
• Remove any obstructions from inside the
machine.
• Paper has not been loaded correctly. Remove
paper from the tray and reload it correctly.
• There is too much paper in the tray. Remove
excess paper from the tray.
• The paper is too thick. Use only paper that
meets the specifications required by the
machine.
SELECTING PRINT MEDIA
You can print on a variety of print media, such as plain paper, envelopes,
labels, and transparencies. Always use print media that meet the guidelines
for use with your machine. Print media that does not meet the guidelines
outlined in this user's guide may cause the following problems:
• Poor print quality
• Increased paper jams
• Premature wear on the machine.
Properties, such as weight, composition, grain, and moisture content, are
important factors that affect the machine's performance and the output
quality. When you choose print materials, consider the following:
• The type, size and weight of the print media for your machine are
described later in this section.
• Desired outcome: The print media you choose should be appropriate for
your project.
• Brightness: Some print media are whiter than others and produce
sharper, more vibrant images.
• Surface smoothness: The smoothness of the print media affects how
crisp the printing looks on the paper.
• Some print media may meet all of the guidelines in this section and
still not produce satisfactory results. This may be the result of
improper handling, unacceptable temperature and humidity levels,
or other variables over which Samsung has no control.
• Before purchasing large quantities of print media, ensure that it
meets the requirements specified in this user's guide.
Using print media that does not meet these specifications may cause
problems, requiring repairs. Such repairs are not covered by
Samsung's warranty or service agreements.
Make sure not to use the inkjet photo paper with this machine. It could
cause damage to the machine.
May 16, 2011 | Samsung CLP 300 Laser Printer
How do I print envelopes in the printer Samsung SCX 4824fn? thanks
• Successful printing on envelopes depends upon the
quality of the envelopes. When selecting envelopes,
consider the following factors:
- Weight: The weight of the envelope paper should
not exceed 90 g/m2 or jamming may occur.
- Construction: Prior to printing, envelopes should
lie flat with less than 6 mm curl, and should not
contain air.
- Condition: Envelopes should not be wrinkled,
nicked, or otherwise damaged.
- Temperature: You should use envelopes that are
compatible with the heat and pressure of the
machine during operation.
• Use only well-constructed envelopes with sharp and
well creased folds.
• Do not use stamped envelopes.
• Do not use envelopes with clasps, snaps, windows,
coated lining, self-adhesive seals, or other synthetic
materials.
• Do not use damaged or poorly made envelopes.
• Be sure the seam at both ends of the envelope
extends all the way to the corner of the envelope.
Envelopes with a peel-off adhesive strip or with
more than one flap that folds over to seal must use
adhesives compatible with the machine's fusing
temperature for 0.1 second. Check your machine's
specification to view the fusing temperature, see
page 82. The extra flaps and strips might cause
wrinkling, creasing, or jams, and may even damage
the fuser.
• For the best print quality, position margins no closer
than 15 mm from the edges of the envelope.
• Avoid printing over the area where the envelope's
seams meet.
Place the side to be printed facing up.
Envelope Preprinted paper Transparency
Punched paper Card stock Letterhead paper
Labe
open the direct paper try on top of your A4 paper try by pushing it!
Apr 22, 2011 | Samsung SCX-4828FN All-In-One Laser...
Mi impresora es canon mx 340 y me dice error 5200 que debo hacer?? ayuda por favor
You need to replace the print head.If a have been useful give me a vote.
Mar 05, 2011 | Canon PIXMA MX340 Wireless Office...
I have a Canon MX 340 printer. I have installed a brand new Canon 211 XL color cartridge, which I believe is compatible with this unit. Whenever I go to print something in color, I am getting the...
Click on Printer & Faxes in the Control panel. Right click on your printer icon. On the drop down menu click on properties. You will see many Tabs relating to your Printer. One of them will be Maintenance Tab Click on it and on the page which opens do the needful.
Jan 20, 2011 | Canon Office Equipment & Supplies
I would like to print a transmission report for a document that I just sent.
Hi
You can print a log of faxes that have been received and sent by the device. Each
entry in the log contains the following information:
• Transmission date and time
• Type (whether received or sent)
• Fax number
• Duration
• Number of pages
• Result (status) of transmission
To print the fax log from the device control panel please follow the directions below
1. Press Setup.
2. Press right arrow to select Print Report, and then press OK.
3. Press right arrow to select Fax Log, and then press OK.
4. Press OK again to print the log
All the best!!
Regards
Nov 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
I called Dell about the same problem. They said it's a motor error. They had me turn off the printer and remove the transfer belt, fuser and all the toner and then turn the printer on and replace them one-by-one, closing the printer door each time to see what the message was.
The printer then began printing before seizing up and reporting the same error message. They ran me through some steps and we realised that I need a new fuser and/or fuser motor.
Try the above. Otherwise call Dell, they were very helpful.
Dec 01, 2008 | Office Equipment & Supplies
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
29 people viewed this question
old marine
old marine
