Question about Garmin GPS
Can a Sigma HRM connect to the garmin edge 800?
4 Suggested Answers
SOURCE: Regarding: Garmin 310 XT-HRM
I have solve this problem from website.
Posted on Oct 08, 2009
SOURCE: Garmin 405 pair to wrong HRM
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80)
Posted on Jan 18, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have misplaced instruction manual
Web search "Garmin Edge 800 manual pdf"
Posted on Aug 14, 2011
When I wear my hrm on he Garmin 301 and cycle, if I am mountain biking in very difficult terrain, my avg hr will be around 145 bpm for over an hour and the calorie count comes back as 130 cal? Impossible,...
This sounds like an OS issue, but may be a hardware failure. Do you ever notice your HRM disconnect and then reconnect to your GPS? If so you may be losing connection to your fitness device which could effect your results. If your connection is fine I would suggest giving the unit a firmware update using Garmins WebUpdater Software. Here is a link http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Feb 25, 2011 | Garmin Forerunner 301
How to use garmin edge 705 cadence/speed sensor
you must disable the gps speed and enable the sensor
Feb 02, 2010 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
Cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Jul 14, 2009 | Garmin EDGE 705
I have installed my Garmin Edge Cadense Sensor, followed the instructions and seems like both the crank arm and wheel sensors are ticking and sensing. However, the edge does not seem to receive the...
There are two tests
705 first - settings, ANT+sport, accessories, check that cadence sensor is set to YES
press the reset on the cadence sensor and rotate the cranks - the LEDs should flash every time the magnet passes the sensor. if not its the position of the magent relative to the sensor that needs adjusting.
Hope that works
Jul 11, 2009 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
Garmin 305 Edge and GSC 10 not receiving one another
Solution copied from Garmin
Feb 22, 2009 | Garmin Edge 305HR GPS Receiver
Garmin Edge 305 HRM problem
Try to pair his unit with your strap and it won't work, you have a bad strapl
Feb 16, 2009 | Garmin Edge 305 GPS Receiver
Garmin Forerunner 305
Make sure the small prong under the battery is bent out a bit, sounds like an intermittened connection problem.
Mar 17, 2008 | Garmin Forerunner 305 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
