Question about The Video Cameras
The firewire cable required is not for pc connection but strictly between cameras there is an additional usb port on the cameras for that purpose
4 Suggested Answers
AlmostBob
  • 550 Answers
SOURCE: Detection of my digital camera
if your pc has firewire IEEE 1394 ports then it does not need them added, if it does not then it needs them added,
firewire, IEEE 19394 cables have a pc end that is flat D shaped and a device end that is rectangular with one side bent in.
if you have a socket on the backplane of the pc that looks like the ones in the background
f2339e9.jpg then you have firewire, else you can buy a pci firewire card for any vacant slot for ~$20.00
Posted on Jul 17, 2008
SOURCE: How to connect my camera to a computer with only USB ports
buy a firewire adaptor for usb maybe??
Posted on Jan 18, 2009
fixyathing
  • 341 Answers
SOURCE: Describe your Sony BRAND DCR-DVD 602E
if you want to connect it a PC you need a video capture device to make use of the s-video and the sound but the video quality is limited to s-video only unless you want to make it as a webcam sort-of. If you want store the video in a computer you can copy the DVD content of the CD into your computer's hard disk.
Posted on Aug 10, 2009
How do I connect my K7 to a 1394 socket
Your Pentax K7 lacks firewire (1394) connectivity, so a connection to a fireware jack will not be possible without purchasing an inexpensive Firewire to USB adapter . From the manual:
Available Ports:
  • USB 2.0 hi-speed, AV out, HDMI out, DC in, cable switch, 3.5mm stereo microphone.
  • Video out: HD (1080i30, 720p30, 480p30), NTSC, PAL
  • Printer interfaces: n/a
The I/O (input /output) panel on a Pentax K7 camera.
You can connect a USB cable from the "PC/AV" on the camera to your computer's USB port with an appropriate cable to transfer image files for editing, etc. Additionally, you can send video directly to a TV with an appropriate cable via the camera's HDMI jack.
I hope this helps!
Oct 04, 2013 | Pentax K7 Digital Camera
I bought my camera used online. The DV cable input does not work. (Unfortunately I was not told about this problem.) I cannot pass the tape to my computer now because of the DV input problem. Does...
I recommend you, test the cable, the Firewire ports. test connection.
Plug the firewire into the camcorder BEFORE turning it on,
You must use a Firewire cable and FW ports (Firewire to Firewire) NOT USB port
Check the cable no bend.
1.- Try with other cable
2.- Try connect a different Firewire port on your PC (or connect to other PC)
3.- To test the FW port on your PC connecting other devices by example external hard drive
If the Hardrive work fine the problem is with your camcorder
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Panasonic DVX-100 Camcorder
I changed my PC and the new one has not the firewire port, only the usb. therefor i cannot ude the cable firewire-firewire that i used im my camcorder nv gs 150. I bougth a cable firewire-USB, but te +c...
I weould try using an Extgernal Drive with both USB and Firewire ports. Connect the camera to the firewire port and the USB port on the external drive to the computer. Not the most elegant solution but will most likely work.
If your computer has facility to add a firewire BUS then you could add one. Usually a blank port called express card 34.
See here for examples: http://www.synchrotech.com/products-expc/expresscard-firewire_00.html
Jun 11, 2011 | Video Cameras
Where can you bay usb cable for panasonc ds 55 camcorder to connect to pc.
This camera downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is usually used only for stills. This camera doesn't have a USB connection at all.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. However, while most PCs have a USB port, they seldom have a Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Jan 24, 2011 | Panasonic NV-DS55B Mini DV Digital...
Cannot transfer tape contents to PC
To transfer video from your camera you will need a firewire cable and a firewire port on your PC. If you don't have such a port you can buy a PCI firewire port.
After you connected your camera with firewire cable you can then use windows movie maker to transfer your video.
See this for more info and photos
Feb 28, 2010 | Panasonic NV-GS400 Camcorder
Jul 17, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Well i don't have a fire wire connection
To my knowledge there is no simple adapter that would interface Firewire to USB. Though both are high-speed bus, there is significant difference between the technologies involved that they can't be joined/integrated nor is it possible to connect a USB device to a Firewire port either directly or vice-versa. Most if not all on the market are a dual/combination Firewire/USB hub but not an adapter.
Alternately:
1. If your computer is a desktop, there are PCI cards that plugs in to one of your PCI slots whose inputs are Firewire based. Here is an example; or
2. If your computer is a laptop, there are PCMCIA cards with Firewire ports. Here is an example .
Pls be reminded that there are 4-pin & 6-pin FireWire DV Cable.
Hope this be of some help/idea. Pls post back how things turned out or should you be in need of additional information.
Good luck and kind regards.
Nov 19, 2007 | Canon ZR60 Mini DV Digital Camcorder
How to download video from panasonic nv-gs15 to Computer
I connected with USB and used MS Movie Maker. The sw that came with the camera only transferred still pictures.
Oct 02, 2007 | Panasonic NV-GS15 Mini DV Digital...
I need a DV cable so I can download my movies from my JVC Camcorder, but my laptop has the USB interface only. Can someone help me find a DV Cable with a USB Interface at the other end? My laptop only...
your camera has a usb connection : wal - mart has general purpose camera to pc cables ( bring your camera to confirm connector size ) also on ebay can get accessory kit for jvc dv cameras .
Aug 05, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Video Cameras Logo
Top The Video Cameras Experts
rdjagger
 Mikey
Mikey
Are you a The Video Camera Expert? Answer questions, earn points and help others
