Question about Whirlpool Refrigerators
Where is a fresh flow filter locate on whirlpool refrigator year 2008 or 2009
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Did you check at the bottom of the fridge behind the plastic beauty panel
Posted on Dec 21, 2016
Whirlpool gold refrigerator freezes up, what can I do?
Hello Trina;
My name is Peter. I am a retired field service refrigeration technician.
Sorry I am not there to help you.
Ok, I have several Questions:
1.) I think you have a bad bi-Metl. On your cooling (Evaporator) Coil. This $20.00 component controls your unit temperature.
2.) You have a air vent from your freezer to your fresh food section. Put your hand in front of the vent. Do you feel cool wet air? Do you feel any air?
3.) Remove the filters. You do not need filters to run.
4.) You can shut down your unit for 24 hours. It will work for about a day, but this will not solve your problem.
I do not know what model number you have, so I can not be exact on how to fix your problem.
Call me @ 443-306-1362.
Feb 13, 2015 | Whirlpool Refrigerators
Where is the water filter for an Amana refrigerator model sqd26ve located?
your water filter is in the upper right hand corner of the fresh food (refrig.) compartment above the upper most shelf in the ceiling
Aug 27, 2011 | Amana Refrigerators
Hi I have kenmore side by side fridge and I want to change wtaer filter but I cannot locate it. Model series noo is 55771. can u please help thanks
It depends who made that refrig for sears,the 3 leading manufactures for sears are Whirlpool and all their filters are in the grill below the the freezer door.,General Electric their filters are in the fresh food (frige) compartment on the ceiling in the upper right corner OR Frigidiare and theirs is right inside of the ref door in the upper right corner by the controls
I hope this helps,
Aug 04, 2011 | Kenmore 57029 Side by Side Refrigerator
The water flow is low it takes so long to get the water
Your problem is probably a faulty solinoid switch, or a clogged filter.
Check to see if you have a filter on the back of the refrig, also check to see if it is located in the area of the motor. If not then your problem will be the solinoid...either try to take it apart if your mechanically inclined, or replace it with a new one.
That should solve your problem
Sep 25, 2009 | Whirlpool GC5SHEXNS Side by Side...
How to change the water filter on a whirlpool refrig model # ED2VEXVQ00. the owners manual has no directions.
The filter is located in the kick plate. There should be a handle you need to turn and le filter will release. The handle aprt of the filter will seperate from the filter and need to be used on the new filter.
Please let me know if this helps you or if I can assist you further.
Aug 02, 2009 | Whirlpool ED2GHEXN Side by Side...
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig/freezer just quite working?
The defrost timer is located in the control panel in the fresh food section.
Look up under the panel and see a opening slightly smaller than a dime.
Put the blade of a butter knife in there and turn clockwise a quarter turn.
If the fridge starts working, replace the defrost timer.
Mar 10, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Where is the release button for the whirlpool gold conquest water filter?
your filter either has a release button directly next to the filter within the kickplate. teardrop shaped button you push, or the only other filter hpusing requires that you twist teh filter out by turning counterclokwise it to is located within the kickplate under the refrig door
Mar 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water filter
are you looking for a replacement filter for your refrig or looking to locate its whereabouts in refrig???? 11 years ago its possible, sorry very probable that a water filter did not come equipped with refrigs.if so it would be in top right corner mounted on ceiling insider refrig.
Mar 11, 2008 | GE Profile TPX24PBDCC Side by Side...
Refrigerators Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
