Question about Cell Phones
Where do I enter my new pin number? - Cell Phones
2 Suggested Answers
  • 103 Answers
SOURCE: i was messing around on my phone and i was going
More than likely you will have to call your service provider. The PUK means your sim card is locked. You can try 111111 or 000000 but usually you have to call and they will you walk through unlocking it. By the way your orginal password is usually the last 4 digits of your phone number. one last note sometime you have too call more than once because not all techs know what they are doing.
Posted on Dec 13, 2010
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
When it ask to confirm new pin or puk code what do you do
Make up your own PIN number and enter it, then enter it again to confirm. Don't use a number that's too obvious, like your address or birthday.
Dec 16, 2013 | Motorola Cell Phones
Enter PUK code, asked for new PIN code, but then get "code error"
my phone puk code got locked. i can unlock the puk code but it says enter new pin code. and when i verify it it says code error
Jun 22, 2009 | Nokia E71 Smartphone
Puk code
PUK code can only provided from your service provider/carrier. Call them and ask them for your PUK code and enter that into your phone. then it will accept your NEW 4 digit PIN number. Do not enter any more random codes as it will permanently deactivate your SIM card and then you need to buy a new one.
Mar 19, 2009 | LG Vu CU920 Cellular Phone
Puk number
puk number is given by the network provider ....
i think you blocked the pin code by entering the wrong pin code for 3 times so it is asking for the puk code ..
to get puk code you must follow these steps :
1. call to your network provider customer care
2. tell them that your pin code got blocked you want puk code
3. if they ask any details about the sim card owner you answer that one ...
4. then make a note of the puk code and enter in to your cell
note :
if you enter the wrong puk code for more than 3 or 10 times your sim will get fully blocked you must purchase the duplicate sim card or you must contact the network provider shoppe ...
Mar 31, 2008 | Nokia N73 Cellular Phone
I need my 4 digit id code b 4 i can get my puk number but i forgot it
you have to phone 07973100450 from a land line. it will ask you for your phone number a few times then it will pass you to  a REAL person who will ask you ask you a few security questions like what are the last four numbers of your top-up card and vol lia that is how you get your four digit id code!!!!!!!
Feb 22, 2008 | Nokia N73 Cellular Phone
Puk code for a nokia6300
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
Feb 22, 2008 | Nokia 6300 Cellular Phone
I've tired to set the PIN code for my Nokia 6085 phone but I cannot. I've entered the PUK code but now it says, "Enter new PIN code:" What do I do? I've entered a code I wanted and other ones on my...
hi
as youve entered the puk code, it asks for the new pin code, the default code was 1234 right? so if you are going to try the new pin code yu can either invent a new pin code or just enter the default code.
hope this helps.
Jan 24, 2008 | Nokia N73 Cellular Phone
K800i puk code?
i need my puk number because of i block my sim and i lost my PUK card
Jan 01, 2008 | Sony Ericsson K800i Cellular Phone
Puk code
please help my sim card is puk lock i nedd a code to unlock it
Dec 13, 2007 | Nokia 6600
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
