Question about Coffee Makers & Espresso Machines
Siemens surpresso compact TK58001 blinking blue and steam (white) light.
If I turn on it's like tries 2-3 times to start and then stay blinking both light permanently. No react any button. Solved. The espresso maker was dissambled and assembled incorrectly by the owner. Mechanical fault. Thanks.
SOURCE: Steam leak in GB Mia Espresso Coffee maker
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Posted on Dec 29, 2008
SOURCE: water light can't be reset
The gray magnetic float can sometimes get jammed. Check to see if it floats back up when adding water. If not, remove cap, reset magnet so it can move freely and replace cap, be sure the magnet floats to the top of its contained space when water is added. The system should then reset.
Posted on Aug 05, 2009
  • 39 Answers
SOURCE: The espresso side of the
The clue here is that the problem involves the hot wate and the single or double espressos. These three functions require accurate water measurements and they are programmable. It appears that the flow meter is not sending the correct information to the control unit. This could happen if you have blockages or if the flow meter is not working anymore. Most likely you need a new flow meter which only costs about $20 and should not be too difficult to replace. It is located between the water tank and the pump.
Posted on Dec 31, 2009
SOURCE: Starbucks Sirena espresso flashing blue light & does not heat up
Gary,
I have the same exact problem with mine starting today, did you get this figured out? I'd love to know if it's fixable or not as I was planning on selling my previous machine. If it's an expensive repair, I'll just have to ditch this one and go back to my previous one.
Posted on Feb 10, 2010
SOURCE: We have a Siemens Surpresso S40, giving 'error 8'
Error 8 indicates a technical fault. Try switching off the main switch for about 1 minute and then start it up again. If the error message persists, you will have to have the machine serviced. The most common fault would be that the machine is blocked.
Posted on Jun 30, 2011
Have solid red light at the 7 o'clock and blinking red light at 11 o'clock
[PDF]Download XD1080 User Guide - Replay XD
www.replayxd.com/downloads/.../Replay-XD1080_User_Manual-EN.pd...
Note: The red LED on the rear will blink when the memory card is not inserted .... The Start REC button should always point up or at the 12 o'clock position for a ...
LG TV Blinking - YouTube
? 0:43
https://www.youtube.com/watch?v=Q8JG53DU6Rk
Nov 5, 2015 - Uploaded by Gillet Gaming
My TV suddenly started blinking when I turned it on at 12o'clock. ... I was going to use it when a few ...Missing: p
Diamond - ndxLocOut
www.nuforc.org/webreports/ndxsdiamond.html
11/7/15 18:05, San Diego, CA, Diamond, 5 minutes, Orange Diamond like .... 8/23/15 21:08, Wildwood Crest, NJ, Diamond, 2 minutes, Hovering red light, ... Diamond shaped brilliant white light with red light in eastern sky at 12 o'clock ..... flashing blue yellow the red at times staying solid red or blue seems to get bigger. 2/27/ ...Missing: p
[PDF]Air-Pak 75i SCBA - User Manual - Scott Safety
Dec 21, 2015 | Televison & Video
I lost the 27208 remote that came with two contractor-installed Hunter fans with lights (incandescent). The fans, lights, & remote have worked fine for 5 years. I purchased a new 27209 remote at Lowes...
If you are trying to use a combination of wall switch and pull chain control, the simple logic in the receiver can't figure out what to do. Try disconnecting all fan power at the source, removing and reinstalling the remote battery, restoring power, and trying all combinations of switch settings and power off - power on operation until you get results (or give up).
Feb 28, 2017 | Hunter Dryers
I have lost my user manual for my Siemens surpresso s 40 . Where can I downloud one ?
You can download it from here.
http://www.siemens-brand.info/siemens-surpresso-s40-manual.html
Jul 20, 2011 | Microwave Ovens
Jun 06, 2011 | Coffee Makers & Espresso Machines
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
The blue light is blinking, the water tank is full, but the water isn't heating up at all. should we return it? Or is there something that we missed? We followed the instructions and are getting no where.
blinking light means the water circuit requires priming.
1 - press power button.
2 - place a cup under steamer and turn on full.
3 - turn steam off when blue light stops blinking (probably a few ounces of water in your cup).
4 - you're ready to rock!
Aug 18, 2009 | Saeco Starbucks Sirena Espresso Machine
Indicator LED blinking, no display on Fujitsu Siemens L19W-2
I've got the same situation. I think it is old enought to break. I just can't turn on the light behind the screen.
Jun 15, 2009 | Fujitsu Siemens Business Line E18-1 18.1"...
Coffee Makers & Espresso Machines Logo
113 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
