Question about Miele Washing Machines
I have a miele W3740 that is displaying a technical fault 63 what is this and can I fix it
5 Suggested Answers
SOURCE: Miele transit rods stuck
My husband was able to pull it out .
Posted on Feb 28, 2008
ngfam1
  • 639 Answers
SOURCE: we have a miele dishwasher
Peace friend,
ngfam1 at your service
Unfortunately I am not there hands on for you !
You will need a good service tech.TO DIAGNOSE THIS ELECTRONIC PROBLEM!
How old is the appliance?
If it is 9 years old or more it may be putting god money into bad!
The new ones pay for them selves in a few years on the savings of energy, and water because they clean better with less water!!!!!!!
A much better n you electric bill!
If you need a good repair Here is who I recommend nation wide.
A&E Factory service open 24/7 for appointments!
1-800-905-9505
Ngafm1
PLEASE GIVE ME THE BEST RATING BEFORE YOU SIGN OFF! BLESS YOU
Posted on Aug 31, 2008
SOURCE: miele washer dryer technical fault
techinscher fehler
wenn neustart ohne erblong
ruben sie den kudendienst
Posted on Oct 24, 2008
ginko
  • 19396 Answers
SOURCE: my miele w3740 wont fill
Hi.
The machine not filling and carrying on with the cycle is quite unusual.
If the machine advances through the cycle without filling, and without manually advancing the cycle, then it is either a defective water level sensing (pressure switch), or a faulty timer board.
In this case the job is done testing or replacing water level switch (part is not expensive), then if that does not work, replacing the timer board.
The inlet valve may also be tested.
If instead you have to advance manually the cycle, check inlet valve and pressure switch.
The inlet valve may be tested reading Ohms ats terminal (must have continuity). A definitive test is done energizing the valve.
The pressure switch is more difficult to test. This has three contacts and two circuits. The pressure switch opens one circuit and closes the other when water level has been reached (tub full). It is usually replaced rather than testing it.
Posted on Aug 24, 2010
How do I fix a F53 fault on a Miele W3740 Washing Machine
First, unplug the washer for minutes then plug in and see if it solve the problem, if not then check the carbon brushes on the motor. These are a part which is expected to wear and when they do the motor cannot rotate the drum, which means the speed sensor thinks something is wrong and throws the error.good luck. Fixing an F53 on Miele washing machine
Nov 02, 2017 | Miele Washing Machines
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
How do I fix a Miele W 2653 Wasker.
Hi dear. You did not mention what fault code but regards rest of your information, I would say 3 factors play up with it.
1- Tacho generator or it's plug faulty on motor
2- Motor Carbon brushes worn out or
3- Power/control unit ELP151-KD faulty.
I can advised to contact your local Miele center to diagnose your machine.Thanks.
Mar 17, 2016 | Miele Washing Machines
Start button light flashing will not start
Hi dear.
You need to contact Miele to assist your machine repair. Description as blow. Thanks.
Start LED flashes rapidly
The drain pump (M8) is activated, level-controlled, for up to 1 h.The buzzer sounds intermittently for 2 min irrespective of its setting.Digital display: - - -
Cause
Technical fault.
Feb 01, 2016 | Miele Washing Machines
Model pw6065. Why is 'technical fault' displayed?
Hi dear. Machine display that message because,there is a problem with machine's components - drive system etc.. Which is not rectified by user. (You can check the fluff filter but you can not test the motor or electronic board.)You need to get professional help from Miele for proper diagnose and solution for it. Thanks.
Jan 30, 2016 | Miele Washing Machines
Flashing F40
I'm sorry to say that this is a controller problem.
The program is interrupted and the drain pump is operated. The display shows. If you have a full alphanumeric display it will show Technical fault F40. Call the Service Department. The buzzer is activated for 2 minutes.
Cause:
The controller has a fault that cannot be repaired by the service department
Remedy:
Replace the controller.
Jul 26, 2011 | Miele Dishwashers
I have opened the drain filter on my miele W3740, but the inside doesn't look like the picture in the handbook. there is supposed to be a bit that goes round. is there another piece to take out before i...
If you are not the original owner - perhaps it was removed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Washing Machines
Watersystem fault
This is a design flaw of the Miele CVA610 and CVA615. If the water reservoir is not properly installed, it will leak into the sump. The only solution is to have a turkey baster on hand for this invevitable situation. This has been confirmed to me by both a Miele technician and their technical support people.
Apr 18, 2008 | Miele CVA615 Espresso Machine
Feb 27, 2008 | Miele Washing Machines
Watersystem fault
Thanks for the solution . I fixed my "Watersystem fault" . The wet switch in the unit is activated when water gets into the base of the machine to prevent water damage to the cabinetry .
Sep 08, 2007 | Miele CVA615 Espresso Machine
Washing Machines Logo
27 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
