My videocon digi marine washing machine always gives me E5 error code..
What to be done..more than 10 times i have repaired it. service people says it is a small mistake but each and every time they charge 300 but not giving a permanent solution for that. Again and again same problems exists. Can Anyone help me what to be done to overcome that without calling the service people..?
SOURCE: Washer keeps giving me a "F51" error code? What do I do?
I placed a very detailed post on how to resolve this issue. If you are mechanically and electrically inclined, this will give you pretty much step by step directions. I also analyzed why this is happening. Please disconnect power before any work... There is 120V floating around inside to bite you! Good Luck, GBaxter http://worldofwashers.blogspot.com/2007/06/cabriooasis-f51-error-codes.html
Posted on Oct 08, 2007
  • 78 Answers
SOURCE: SERVICE CALL 188 : FATAL ERROR
Service Call 188: Error: Sub-CPU Communication Error
1- Check the connection of the S2M board.
2- Replace the S2M board.
If the problem does not go away after a reboot you'd better call Oki (it should have a 3 yr. waranty) or an experienced oki technician.
This is not something you should want to fix yourself. The replacement of the s2m board is not an easy task (even for an experienced mechanic)
Posted on Oct 09, 2008
  • 27 Answers
SOURCE: need codes for starview ntl 09/10/09
00 - a9 5d 4e fe 20 e1 2d 03
Posted on Oct 09, 2009
Testimonial: "it works thankyou"
SOURCE: We are getting error code - 00010014
The same has happened to me I replaced one of the inks and got the error message 0010014. I replaced the ink cartridge with another and it began working again or maybe this link might help you.http://www.epson.co.uk/Printers-and-All-In-Ones/Large-Format/Epson-Stylus-Pro-7800/Drivers-Support?target=article&extn=.html&articleId=4286
Good luck!!
Posted on Sep 08, 2010
jay767
  • 386 Answers
SOURCE: the printer is giving me
Hi Good day!!!
This error message "Service Req E527" means that the toner carousel housing the toner cartridges is obstructed, or is unable to rotate correctly. It can be caused by installing a toner cartridge incorrectly.
Solution 1:Check that the toner cartridge at the front of the printer is installed correctly.
Solution 2: Manually remove all of the toner cartridges.
Close all the covers, and then power the printer off.Open Cover B, and then remove the photo conductor unit (PCU).Turn the toner carousel by hand to line up a toner cartridge with the front of the printer.Open Cover A.If the toner cartridge is not in position to remove it, close Cover A and repeat the steps above.Remove the toner cartridge, and then close Cover A.Repeat all the steps above until you have removed all four toner cartridges.Reinstall the PCU.Close all the covers, and then power on the printer.Open Cover A and Cover B.Check thoroughly for any jammed paper, foreign objects or damaged parts.If you can locate an obstruction, remove it. Then, close all the covers and restart the printer again. If you can identify any damaged parts, there is an obstruction you cannot remove, or there is no change after restarting the printer, then contact Epson for further advice.Reinstall the toner cartridges (Follow the prompts on the LCD display), and then test the printer.
Don't forget to vote thanks!!!
Posted on Nov 02, 2010
E5 error in videocon topload washing machine drain system is allready cleaned
have you unplugged for a minute then repulsed to reset the EEPROM. (circuit board).?
hope this helps.
Jan 05, 2018 | Washing Machines
Kenwood Model # KWM 7020FAF, Please note this washing machine is giving error E5, and we are unable to understand this error/ issue. please guide.
E5 unbalance load either put more item in are take some out unplug washer for 5 min should reset the code
Dec 18, 2017 | Washing Machines
E5 error on Videocon washing machine how to solve
E 5 ERROR IN VIDEOCON TOP LOAD WASHING MACHINE DRAIN SYSTEM IS ALL READY CLEANED
Sep 22, 2017 | Washing Machines
What does an E5 code mean?
Make and model helps, but here are all the E5 Error Codes we get asked.
On a cellphone?
E5 code Google Search
On a washing machine
e5 error code code washing machines Google Search
Dishwasher
e5 error code code dishwasher Google Search
Stove / Cooker
e5 error code code stoves Google Search
Fridge
samsung fridge e5 error code Google Search
Aug 27, 2017 | Cell Phones
Digi marine videocon water not draining pl help
You need to run spin program again, it may need doing several times. Usual cause is over fill machine with washing.
Mar 04, 2016 | Washing Machines
I can't find my manual of my AWF-606WS AMERICAN HONE WASHING MACHINE. There is a problem E5 always appear every time I wash, I don't know what does it means.
contact the machine manufacturer's customer support and you can ask them what error E5 is you could also ask for new manual and that might have error codes in it , make sure you have serial number and 12 digit number .
Dec 26, 2015 | Washing Machines
Samsung dv665jw error code e5
Please find list of error codes and their remedy in the link below
Error codes
Oct 03, 2013 | Washing Machines
Onida wash machine error code e5
what is E5 error code in onida sparkle fuzzy logic
Jan 04, 2013 | Washing Machines
My Videocon Fully automatic top load washing machine (Digi Dolphin Dlx 7 kg) gives E9 error and stop functioning
Hi
E9 means the water level sensor is defective or the pipe connected to it is faulty.Generally error E9 means a problem with your water pressure sensor. do you have water in the tub? Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
