My MP280 was installed on a windows7 laptop my new windows10 laptop dose not have a disk drive how can I load it.
    Top Expert:
  • Computers & ... Master
  • 24,750 Answers
Copy the installation disc to a USB drive.
Posted on Dec 19, 2016
How install infernal on windows10.i inform you that i have windows7 version i download a widows10 version and transform to windows10 from windows 7.but i not get full version of windows install
there has been problems when upgrading from win 7 to win 10
it is better to get the win 10 program and download it as the up grade has compatibility problems
Sep 24, 2017 | Computers & Internet
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
I have doughta new Acer computer with preloaded windows 10 which I hate my computer has never had windows 7 install which I want instead of windows10
Purchase win7 on CD and place it in the DVD drive. Boot from it and format the drive. Then you can install it as an operating system. Don't forget to install all of the drivers, from the manufacturers web site, NOT from microsoft!
May 17, 2016 | Acer Computers & Internet
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
I have a Sony VGN-NR180E laptop, the hard disk had needed changing so i bought a new one. installation went perfect, up on loading up my new os windows7 in my laptop, it shut off due to no power ( was...
I suggest you reinstall the windows 7 again. The installation was interrupted because the battery ran out of power, the result was a corrupted and incomplete installation of windows. And that is the main reason why you are just getting a blank screen.
Sep 06, 2011 | Sony Computers & Internet
Hi, you may download PIXMA MP280 driver through this site:
Once you're in this page, please scroll down and search for the operating system you are using, then "enter the code" and click "download file" as shown below.
Start the download by hitting on "Click to download mp280swin100ea24.exe"
Once downloaded, please follow the installation process. I hope this helps.
Aug 18, 2011 | Computers & Internet
My toshiba laptop satellite model L650 windows7 installed is 64bit, can i reflace it to windows7 32bit?
Hi and Welcome to Fixya
Yes, you can change the operaitng system to Windows 7 32 bit. All you need to have is the licensed version of windows 7 32 bit. Boot upthe computer from that disk by pressing F12 key when you turn on the computer. Select the ODD drive to boot the computer to the windows 7 disk then you are good to go.
Thank you for using Fixya!
Feb 21, 2011 | Toshiba Computers & Internet
Dssusb.dll and dssusb1.dll error on software load on new laptop running windows7
copy both dssusb.dll and dssusb1.dll to C:\Program Files (x86)\Olympus\DSSPlayer or where ever the program has installed. Both these files are on the installarion disk.
Jan 09, 2011 | Olympus DS-2 Digital Voice Recorder
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
