How do I adjust the back feet on my DW009? Had new flooring after installation. Just bought new machine but can't get old one out! Front feet adjust but not back Ines. Any help would be appreciated.
  • 3,015 Answers
Unlikely that the back feet are adjustable.Sounds like a bit of brute force is needed. Adjust the front to the maximum height Try with a torch and mirror first to see under the machine.
There may be room to insert a stout plank of wood and hopefully get a pivot underneath to make a fulcrum.
Posted on Dec 19, 2016
5 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Machine too heavy to move
The only way to move a heavy machine is to push on the front and tilt it back then walk it into position.
you may need help.
you can get sliders at walgreens but they may cause issues as they wear.
Posted on Jun 04, 2008
  • 1937 Answers
SOURCE: I have a Kenmore topload washing machine, model
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23034101
Look at the section for the Machine Base.
Kenmore / Whirlpool top load washers use a set of springs between the top and base of the tub, along with a set of vibration pads to control vibration and walking of the machines.
It's possible that one or more of the springs has come off or the pads have worn enough that the top frame is rubbing against the lower frame.
See the following Whirlpool / Kenmore service manual to better see how these springs / pads are used.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
You will have to remove the cabinet to get to the springs / pads. Here is a description of how to do it.
It appears that your washer may not have end caps on the console that remove. If so, slip a thin putty knife under the ends of the console to release the clips that hold it to the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=ad0510c0d20a18338ae7d4adf956f0ca
Posted on Oct 27, 2009
  • 1937 Answers
SOURCE: I recently had to move
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24872300&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Posted on Jun 11, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a Kenmore HE
Make sure the floor is sturdy. Reinforce the floor with at least a 3/4" thick plywood if necessary. The next thing to look at is the rear tub bearing and the spinner support, a.k.a spider assembly, the three-arm assembly that holds the basket to the shaft. Try to move the basket in all direction then turn it manually and check it for any noise. Do the same with the drive pulley. If the vibration during the spin cycles or when the basket and drive pulley are turned manually is accompanied by a clanking noise, then you likely have a broken spider assembly.
Here are some videos showing what a broken spider assembly looks like and how it makes the clanking noise when it is completely broken.
Posted on Jul 09, 2011
How do I adjust the height of my whirlpool ingregrated dishwasher
Usually on the two front feet are adjustable. To set the back feet just pull the machine towards you temporarily raising the back of the unit off the floor, this will make sure the rear feet drop down fully. Then set the back down again and adjust the 2 front feet to level.it.
Feb 15, 2015 | Whirlpool ADG8410FD_BK Dishwasher Full...
Fridgaire vibrating and moving ahead during spin cycle
Being a new installation it will need its feet adjusting ;-0)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 30, 2011 | Frigidaire ATF6000ES Front Load Washer
Is my washing machine too old and should I get a new one? It is a Kenmore Ultra Fabric Care III serial# CD1604311 and model# 92592400. The inside basket bangs around alot when in use. I tried to even the...
Although you say it's level I would recommend you try my method to make absolutely certain before considering spending money!
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
John C
Jul 16, 2011 | Washing Machines
I just bought a new washing machine. I can't seen to get it balanced. When we adjust the legs and try the machine, it doesn't seem to hold and bounces around again. Is there anything else we...
Quite often the adjustment feet have a locknut between the feet and the base of machine. Wind the feet down to required position and then wind the locknut up tight against the base. Nip the locknuts up with a wrench to keep them there. The locknut could be a plastic wheel type.
Jun 13, 2011 | Frigidaire FTF530FS Front Load Washer
While on rinse cycle. the machine make a loud of noise, the whole machine shake alot. i replace all the 3 spring, and one spring on the back. and notice there is 2 pin that drop. so i re scure the pin. but...
I had the same problem. It was a combination of unbalanced loads and the machine was not level. I used a torpedo level I bought at Lowes to check the level of the machine. First, standing in front of the machine, put the level on the front edge of the machine top. Measure left to right and using a wrench adjust the screw feet on the bottom front of the machine until you reach level. Then standing in front of the machine, grab the two back corners of the machine console body (do not use the control panel for this as you will break it loose from the body). pulling up and forward, rotate the machine so that the back feet are lifted off the floor, while the front feet are still making contact with the floor. This allows the back feet to automatically level the machine. Using the level check from front to back on the left and right top of the machine body to ensure level is reached. Repeat the entire process until you reach an acceptable level condition on the washer. Note: All level measurements must be made on a flat surface of the machine.
Jan 19, 2011 | Whirlpool Washing Machines
We recently bought a new washing machine, front loading, and it seems to enjoy dancing across the floor when it spins, any ideas what we can do to prevent this, the floor has a laminate finish.
The adjustable feet under the machine are supposed to be fitted with rubber cups. Make sure the machine doesn't rock around when pushed and pulled in several directions--you may need to adjust the feet so that the machine sits level and firmly. If it really gets to hopping after you have checked the previous items, then the tub suspension system inside the case may hung-up in some way. That would appear to be a warranty item. Hope this helps!
Mar 28, 2010 | Tecnik TKL9260 Front Load Washer
Noisy washer and jumps around
It could be a few different issues. Check to be sure your washer leveling legs are set correctly. Also many newer washing machines have what they call shocks, stabilizing struts. Those can fail over time and cause your machine to be off balance and walk the floor/vibrate. When is the machine nosey? If when its filling with water it could be a water inlet valve. Or during the spin cycle it could be a drum roller, belt, pulley, Or top bearing glides to name a few things.
May 24, 2009 | Whirlpool WTW5300SQ Top Load Washer
Hotpoint wf620 aquarius very noisy and not letin any water in
A washer usually shakes or vibrates when it isn’t sitting firmly and level on the floor or because it has an out-of-balance wash load. First eliminate the possibility of the latter—adjust the load if it has scrunched up on one side of the tub. Then check the machine for solid, level support. For the machine to work properly, the floow must be flat, level, and strong enought to support the heavy, water-filled washer without deflecting under the load.
1) Unplug the washer.
2) Look under the washer, and make sure all feet are resting firmly on the floor.
3) Make sure the front legs have locking nuts to keep them tight and that the legs have rubber caps. If they don’t, buy these parts and install them.
4) Make the front feet as short as possible by screwing them up into the machine. Place a level on top of the washing machine and adjust the front feet slightly if needed to level the washer; do not fully extend them.
5) If necessary, tilt the washing machine forward. This will let the back feet self adjust. Recheck for level, and adjust the front feet again.
6) Plug in the machine, and run it empty through the spin cycle to see if it still vibrates.
7) If it does, call a repairperson or the manufacturer to ask about solutions.
Thanks for your question
Dec 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Very loud
Make sure that it is level. There should be self adjusting feet on the back of the washer. Just tip it forward towards you till it is barely off the floor then sit it back down gently. Then with a level across the top front of the washer check for level. The front feet and be turned to adjust for level. Make sure you check the front to back on the top also. It may take a little while to adjust it to level. You can put a 2x4 under the front to hold it up while you ***** the feet in or out as needed.
Mar 10, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
