Question about Bulldog Remote Starter & T-Harness Kit for 95-99 Nissan 200SX/Altima/Sentra
I turned the ignition key and I can see all the lights in dash board, I even used jumping cables and the nissan does not start. What should I do
Check your starter i had the same problem
Posted on Oct 28, 2009
  • 34 Answers
Test spark plugs, check that fuel is rising.
Posted on Jul 30, 2009
06 pontiac grand prix wont start no clicking when you turn the key over even jump starting the battery, has dash lights & radio & parking lights. battery tested good. put a used starter & altinator on
Used parts such as starters and altinators don't last. It might **** but it sounds like you need to buy a new starter,altinator, and battery. Or just start with buying one at a time.
Dec 06, 2011 | 2006 Pontiac Grand Prix
The car is starting 1/10.. Firts i turn ignition key and the light in the dash are lighting up good,i turn the key and nothing happen.I take the off the ignition and it make a tic-tic-tic on the...
We have to assume the battery is usable, if not, anything else doesn't help. A couple of possibilities- First, get a simple, cheap device that uses a 9V battery and the car's cigarette lighter to prevent losing anti-theft codes. Once this is plugged in, remove the negative battery cable first, then the positive. CLEAN the battery connectors and terminals. Try to start the engine. If it still does the same thing, remove the negative battery cable again and follow it to its next connection and clean that point. While it is off, remove the other end of the positive cable which goes to the starter terminal and clean both points.
While under the hood, look for the cable connecting the engine block to the body of the car and clean both ends of that cable.
If the problem is still there, it can be related to one of these; the ignition switch, the starter solenoid or a corroded fuse connection. The starter is not protected by a fuse but the solenoid may be.
Good luck-
May 28, 2011 | Nissan 300ZX Cars & Trucks
Put the key in the ignition and nothing happens (the dash all lights up windows work) but not even a click , happened once this morning and we rocked the car and it was fine has started 2-3 times since and...
Sounds like either bad battery or really dirty battery cables. Have you tried jump starting? I'd first start with cleaning battery cables top & BOTTOMS. Everyone cleans top because they're easily accessible, but the bottoms are exposed to dirt & road grime and are usually the culprit. After cleaning cables, if problem exists then replace battery. You can verify battery by having any good parts store "load test" battery.
Mar 22, 2011 | 1994 Nissan 240SX
I just purchased 1198 Nissan frontier. I had to replace the battery right away. And after installing a new battery. I turn the key and nothing. No dash lights. No buzzers or clicks. nothing comes on. No...
use a test light and follow the main supply wires going into the cars cab keep poking thru the insulation with the tester probe at regular intervals until you dont get any power. there might be a fusable link or a maxifuse somewhere blown. check fuse panel for pwoer and check the wires to and from the ignition switch.
Sep 23, 2010 | Nissan Frontier Cars & Trucks
1994 Nissan Pathfinder won't start, even jumping it.
I had a similar problem w/ my 94 Pathfinder. The problem was a cheap security system that was offered in that year model and the wiring between the ignition and the starter was run through this system. The dealership was able to by pass the security system and this fixed the problem. For years other mechanics told me it was the starter but I knew it was something else.
Jul 14, 2009 | 1994 Nissan Pathfinder
Motor does not start when i turn on ignition
did u have the alternator tested to see output get a jump if the car starts takeit to a auto zone have him test the battery and alternator for free
May 03, 2009 | 1998 Volvo S70
Hyundai Tiburon Won't Start
Possibly the alarm cut-off switch? or Ignition key switch (or wires) going bad?
But you mentioned you tried to jump start it and it did turn over?
IF so, you could have severe corrosion or loose connections of the battery cable both at the battery and at the termination points, such as ground and starter motor.
Check that the battery wires are tight and clean at the battery posts and at the other end.
Again the No lights suggests either the alarm cut-off, or an absolute disconnected battery cable.
Finally, it could be ignition fuse, Check fuses. Ignition key switch.
What makes this hard is that you suggest it would turn over with another battery connected. This makes no sense.
Good luck
Mar 16, 2009 | Hyundai Motor 2000 Tiburon
Won't start
There could be a short in or near the ignition switch.
Aug 25, 2008 | 1997 Nissan Pickup
Bulldog Remote Starter & T-Harness Kit for 95-99 Nissan 200SX/Altima/Sentra Logo
226 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
