Question about Konica Minolta Bizhub C220 Color Copier/Printer/Scanner
I'm facing an error code at the starup code c-3421 on konica c220. please help me what i have to do?
  • Konica Minolta Master
  • 6,696 Answers
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 12, 2017
5 Suggested Answers
  • 158 Answers
SOURCE: Error code EA3226 when I try to scan to e mail on
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
Posted on Dec 04, 2009
firecontrol7
  • 6696 Answers
SOURCE: E-56-2
Sir,
You have a loose connection between the image control board and main operation board or one or both are dead. mite have a technician look at it. Unless you are confortable taking back cover off and checking board connections
Posted on Apr 17, 2010
Bizhubman
  • 108 Answers
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
Posted on May 19, 2010
  • 4 Answers
SOURCE: While doing printing after 6 or 7 print, the error code c2552 appear in konica Minolta c220, I have open the front door, after that error gone, Again same problem coming after 6 or 7 print.
C2552 Abnormally high toner density
detected Cyan TCR Sensor
• TC ratio in the developing machine, which is
determined by Toner replenishing amount control
mechanism, is 12 % or more for a given number
of times consecutively.
1Clean the TCR Sensor window on the
underside of the Imaging Unit if dirty
2 Reinstall Imaging Unit
3 Change Imaging Unit
4 Change PWB-M
5 Change PWB-MFP
Posted on Jan 24, 2017
Konica Minolta bizhub C220 error code C-D010
disable hard discor try to do physicall format in service mode
Feb 18, 2016 | Konica Minolta bizhub C220 Color C / M / Y...
Error code c-3421 in bizhub c220
Hi
The following site gives error codes for a wide range of printers and their user guides can be obtained as well.
Error Codes Konica Minolta bizhub C220 Code C3421
Your error comes up as follows:-
Code:- C3421
Description:- Fusing heaters trouble (Heating side)
• Detected temperature of the heating roller thermistor/C does not go up a given range of temperature even after a lapse of given period of time at warm up. • Detected temperature of the heating roller thermistor/C does not reach to a given temperature even after a lapse of given period of time after warm up is completed.
Remedy:- 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 6 Change PRCB. 7 Change DCPU.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 05, 2014 | Office Equipment & Supplies
Bizhub c203 with c3421 error code
http://www.oasq.com/how-to-clear-error-code-c-3421-on-konica-bi-thread-733519-1-1.html
May 08, 2014 | Office Equipment & Supplies
Fusing heater trouble konica c220
You need to change the thermistor on the fuser unit.
Sep 11, 2013 | Konica Minolta Bizhub C220 Color...
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Mar 13, 2012 | Konica Minolta Konica Bizhub C353 Drum...
How to clear error code c 3421 on konica bizhub c253
To Reset:
May 19, 2010 | Konica Minolta bizhub C250 All-In-One...
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
Nov 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Please help me for the internal error (C-2553)
i have konica minotla bc352 its giving error c 2553 and megenta background
pl help me
Mar 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub C220 Color Copier/Printer/Scanner Logo
54 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
