Question about AEG Washing Machines
I need to replace a power on off switch for an AEG OKO Lavamat 2442 top loading washing machine Product code 913 734 381. What is the part no and/or where can I get one in South Africa?
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
  • 174 Answers
SOURCE: aeg oko lavamat 72600 update, ce error code
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Posted on Jul 20, 2010
Testimonial: "Cheers thanks very much, washer now working, great help"
  • 3917 Answers
SOURCE: AEG Washing machine Oko Lavamat
The C9 on some AEG LAVAMAT models like the 71400, 72600,74620, 86720 and possibly others, is the same as the above F9, and is usually MOTOR BRUSHES WORN OUT. After replacement, you will need to clear the fault indication held in the PROGRAMMER PCB logic: With the Switch in the OFF position - Press and hold PRE-WASH and SOAKING buttons in at the same time, then turn the control knob to Short Spin. Wait one or two seconds and all the indicators should illuminate. Then turn the control knob to OFF. All the indicators should go out. Then try and use your machine as normal. This should clear the C9 error code. If it does not -check there may be another fault present.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Posted on May 29, 2011
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Aug 24, 2014 | AEG Washing Machines
Check the drain filter, see if the hose is not clogged (blow it), verify proper operation of the pump and the pressure switch if necessary
May 30, 2011 | AEG Lavamat W1050 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
