Question about Garden
2010 2554 tractor had click and it stop pulling
Blades will not stop after disengaging blades drive belts.. I just put new blades on it and have an extra spring. Not sure where it goes cause manual is not very clear?
i hate to assume, but if the tractor is newer it has a electric PTO and a switch on the dash, most are a push/pull type knob, with the mower off pull know in and out and see if you can feel a click or step in the switch if not the switch may be bad also with mower off turn the key on and listen for a click from the PTO if you do and the switch is off it is broke and stuck in the on position, if your switch is a toogle switch up/down (flip switch) same theory just an other type, but either way unplus the wire plug from the switch and start up tractor and if blades are off you know you have a bad switch just replace with a new one..
Mar 10, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor
the riding tractor brake pedal pulls a rod. follow the rod to the brake assembly and look for a stuck lever. Grass and other crud can make it hang up tight.
May 17, 2013 | Garden
Tractor will not start
There is an automotive fuse by the fuel tank, this controls the whole electrical system.
Jun 09, 2012 | Craftsman Garden
Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The deck blades stop turning in reverse unless switch is pulled.
This is a safety feature that is not that hard to do so i say live with it.You do'nt have to hold it up just pull it up before you start backing up and once your moveing you can let go without it shutting off the deck until the pedel returns to neutral again,all tractor have it by law after a certain date so jumping around it is niot a good idea.
Nov 30, 2009 | Garden
Model # 917256563 19.5 hp Craftsman. Ran fine until the front tire fell in a small hole. I heard a poping noise from rear of tractor I lifted the wheel out the hole and now the tractor will only run if I...
If the tractor stopped abrubtly, you may have bent something pertaining to the frame or the clutch pedal assembly if you caught your weight on the clutch when it stopped. Sears parts.com has en exploded view if you enter your model number
Aug 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
