Cannot get a signal from my ariel to my umc 15inch lcd tv receivor with my new ariel
Coldcut
  • 1554 Answers
SOURCE: TV signal problem?
look on the lcd website and see if there is an update for the lcd bios.
if you play a dvd is the issue the same.
try using a different connection to the cable box sometimes thats the issue.
try channel 3 /4
then composite video
then component 3 color
then DVI or svideo
with one of these you may see and improvement in video and sound
Posted on Feb 18, 2008
jmagnan
  • 57 Answers
SOURCE: tv reception
He might be on the wrong input
Posted on Feb 27, 2008
SOURCE: i keep losing signal on
Try updating your router's firmware. A recent update from microsoft might have caused this.
Posted on Oct 18, 2008
  • 9 Answers
SOURCE: I have just bought a
! When you tuned tv did you save it? 2 do you have analogue & freeview on your set? maybe you've hit the freeview button.
Posted on Mar 10, 2009
SOURCE: will umc tv run on 12 volt battery?
yes you can plug this set straight onto a twelve volt battery it is designed for that purpose ie the motor home and campervan market ,i own one of these sets ,it is the best portable tvdvd ive seen so far ,hope this helps your query.
Posted on Jul 15, 2009
How do I find the serial number of my technika 17"lcd tv+dvd
If you need to call the helpline, you will need the following information.
Model Number __________________________ (Can be found on rear of TV)
Serial Number __________________________ (Can be found on rear of TV) http://www.umc-slovakia.sk/new/15/umc/22-36DVDIPOD.pdf
Feb 14, 2015 | Televison & Video
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
My UMC 22" LCD TV
Please don't just keep trying random fixes until you've spent more money than it's worth. Research the problem online, and if that fails, there are still some good TV repairmen out there, but it may take a lot of digging.
Jan 10, 2018 | Televison & Video
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Will umc tv run on 12 volt battery?
Mar 29, 2009 | Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Ariel socket in tv has broken
The best thing is to replace the signal board, that costs $24.
Check here for the part : Polaroid Replacement TV Parts
You find the part on Ebay here.
Part number is 200-013-JK371-1AH FLM-323B
Oct 24, 2008 | Polaroid LCD-2050 20 in. Television
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
