I need new bord - Computers & Internet
I need 2 new feet for my key bord an thenumber pad enter key for my key bord thanks
Hi Stephen. It would be easier to replace it with another keyboard as those replacement parts will be hard to locate. I found a new keyboard using this search "GE (98056) Keyboard" and found one at amazon.com and one at ebay.com for around $40 range. If that is too much, you can use any USB keyboard you like instead, assuming you have an unused usb port left, that is.
Jul 17, 2013 | GE 98056 Keyboard
Ge regigtor. not working
You got the wrong or a bad board. Willing to bet it's the wrong board.
Mar 13, 2013 | Refrigerators
Programme keeps revolving non stop
the program bord has packed up,,,fiting a new bord will sort it out
Dec 01, 2010 | Hotpoint Ariston AWD129 Front Load...
I have new case,but can't connect audio,front usb,mic,5v,ground e.t.c cables from case to motherboard because they are not marked on it.Motherboard model HP compaq d530 xw3100
we see each casing have written cable knobe.as hdd/ reset/ power/ we join it on bord .there diagram on about this led/cable.2/ we give power to hdd/ cd room from smps3/ we join fan squire port on bord . fan port is written in bord. 4/we join data cablehdd/cdroom from on board.
Nov 04, 2009 | HP Compaq Motherboard
We purchased a new computer and can not find the disc to reload our mouse.. can you help? Please :)
there no need softwere for mouse, if you have wire less keep battery on mouse and key bord. then join usb sencer in your computer which you get when buy mouse and key bord . its automaticaly detated mouse and key bord in your computer.
Nov 02, 2009 | Logitech Cordless Mouse
Maytag mde6800ayw dryer. no power at all. light works inside and im getting 220v. im told that there was a power outage and when it came back on the dryer was dead. im guessing the control board.
your guessing right then,,,
often if the power is cut off when its restored the sudden punch of power can blow the bords chips up,
its nothing new,, if they has a soft start it would not happen to them,,
sorry you need a new program bord
Oct 31, 2009 | Maytag Neptune MDE6800 Electric Dryer
The control circuit board for my toasteris cracked. I need to get a replacement. The no on the board is PCB016
if your realy handy with a soldering iron you could re-solder all the joints and put a bit of wire over them too, if the circuit bord is in two bits clue it together first then skrape off any paint oner the copper tracks that need to be solderd before soldering them together again its worth a try a new bord would cost more that a new toster?
Oct 30, 2009 | DeLonghi Classica CT14 Toaster
Can't scan, error 2,114,0
logic bord problem youprinter new logic bord ching
Oct 05, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I can't get a video signal to the monitor. Have a new graphics card.....no signal????
1/ first change motherbord on your desktop.if it is work (your old bord is damage ).then keep graphic card/ vj card on old mother bord slaut. if not work . it is seriously problem.mainly in pinless bord we can"t repair it. change or took it on export
Jul 10, 2009 | Intel DX48BT2 Motherboard - X48, Socket...
Computers & Internet Logo
David Payne
David Payne
