What is the best impedance setting and equalizer hookup on a fisher ca-2300 integrated amplifier. i would like a copy of the owners manual. thank you
  • 105 Answers
sorry to send you to safemanuals they don't have that manual. you may have to look to see where it was made and then go to to customer support and contact them.
Posted on Oct 01, 2008
  • 5 Answers
SOURCE: How to connect the FISHER EQ-273 equalizer to the FISHER CA-885
It goes between whatever you are using to create the sound and the input to the amplifier.
e.g. for a standard HiFi.. HiFi aux out to equalizer input... equalizer output to amplifier aux input.
Trying to keep left and right channels the same through out. They are usually colour coded. Red = right Left = white.
Hope that helps.
We all start somewhere
Posted on Mar 30, 2009
SOURCE: HI I have fisher integrated
Hi, I came across this model amplifier in a Goodwill today - was checking online about specs (which is how i found your post) to see if it was worth purchasing and reselling. If you're still interested please drop me a note directly at jtimleck &&**##_at_%%$#@mac *&^ dawt calm
Posted on Jan 15, 2011
  • 5603 Answers
SOURCE: Integrated amplifier for Mordaunt-Short Avant 908i
Use an amplifier with NO MORE than 150 Watts per channel or you be buying new speakers. At this power level don't expect booming bass boost without damaging the speakers. The Rotel generates 130 per side which is very near the safe maximum for those speakers... and the specs look good. If you are not satified with the sound, the speakers are LIKELY the problem. Look at getting good commercial speaakers instead of CONSUMER grade speakers. Go to a music store dealing with bands and musicians and view the products they have to offer. Consumer speakers often fail when people turn up too much bass. At high listening levels hearing damage can result.
Posted on Aug 03, 2012
  • 966 Answers
SOURCE: I need an owners manual
sarah you may search this manual on Google. I am sure you will find one free.
Posted on Jan 16, 2014
Fisher equalizer 2322
"Rec" is a send (output from Fisher to an external device) and PB (playback) is a input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
Dec 12, 2013 | Fisher Vintage Ca-880 Integrated Amp...
3 monitors required for emx5016cf-- daisy chain? Any way to EQ monitors?
There are several ways to solve the problem. Probably the simplest technically is to connect a powered speaker (or separate amplifier) to one of the ST OUT jacks in the master section of the top panel for the third speaker, and connect the other two speakers directly to the speaker jacks on the back. The drawback to this arrangement is the possibility of problems with setting the frequency correction (automatic equalizer adjustment). You would have the same problem with paralleling speakers (more on this in a subsequent paragraph) on one channel. It may help to use a second speaker from each channel for the "third" monitor so the automatic EQ is working with the same setup on each channel.
Another method is to daisy chain the mixer by connecting another mixer/EQ amplifier to the pre-EQ SUB OUT jacks to drive the third speaker. This permits independent equalization and level setting for that monitor. (You would probably set this EQ first with the main outputs all the way down, then set the EQ on the two primary monitors.)
Regarding multiple speaker connections to the speaker out jacks: Do not connect them in series ("daisy chain"). Unless they are very closely matched, varying responses in the speakers may cause distortion, and each will be running at about half power. You can connect them in parallel (the + terminals are both connected to the SPEAKER jack + terminal, and the likewise the - terminals are all connected together), if the total impedance is as least 4 Ohms. Note that when two speakers are in parallel, the impedance is calculated as follows: (X1*X2)/(X1+X2), X1 is the impedance of one speaker, and X2 is the impedance of the other. In other words, parallel connection reduces the impedance, and too many in parallel will overload the amplifier. If both speakers are 8 Ohms, this works out to 4 Ohms. See page 29 of the owner's manual.
Dec 02, 2013 | Yamaha Emx5016cf Emx-5016cf Powered Mixer
What number should i set on each channel running behringer vp1220 speakers
Go to owners manual in the specifications page.
Will show the impedance, you should mach the impedance output with the speakers,2,4, 8 Homs impedance and how many watts RMS or peak.
Oct 11, 2012 | Behringer EUROPOWER EP2500 Amplifier
I have a Fisher CA-871 and all componets, I misplaced the hookup digram for the amp to all componets. The problem i have is only the EQ-871 to CR-W870 and also to tape deck. I hope you can help Thank...
if you visit the link below you will find hookup diagram for your need..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
How do I wire my equalizer into my audio system?
Jun 23, 2011 | Audio Players & Recorders
My SU-G95 provides for switching between two sets of speakers (A & B) but there is no way I can see to get sound through both sets of speakers at the same time! Any suggestions? I expected to see the...
I can't find a manual or a decent picture of the rear panel but maybe that's because they don't want you running speakers in parallel as it may present a dangerously low impedance.
If you REALLY want to risk it just wire both sets of speakers to the same posts and watch out when turning up the volume. Monitor the amp for excessive heat in case it starts to cook itself. If theamp shuts down even once, UNDO the scheme.
The safer way, assuming the two sets of speakers' relative volume levels are about equal, is to run them in series with each other and present a higher (safer) impedance.
The recommended impedance is probably silk-screened right on the back.
Apr 15, 2011 | Technics SUV500 2-Channel Amplifier
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Hope that helps.
Mar 18, 2009 | Audio Players & Recorders
It all depends what other devices are to be installed to the Yamaha Ca-400. Perhaps your best bet would be to consult the owner's manual. For the owners manual of a Yamaha CA400, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 03, 2008 | Yamaha (AX497) 2-Channel Amplifier
63 people viewed this question
