Question about Cameras
Camera not charging
Why is the charger light flashing amber light and it is not charging the camera.
  • Anonymous Apr 01, 2014
    i put my battery into the charger and plug it into the wall and the charge light is not lighting up. is it the charger or the camera.
    Problem Solver:
  • 6 Answers
Probably a battery that has gone bad. Try another battery.
Posted on Jul 21, 2009
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
When charging amber light flashes
What model Samsung camera? With many cameras, a flashing amber light is normal while charging. Once fully charged, the light may turn green and/or stop flashing.
Aug 04, 2013 | Samsung Cameras
Battery charge light flashing amber
Ok, lets start slowly, do you have both a new battery and a new battery charger? If both attempt to use your old battery with the new charger. Also could be a bad charger or a shorted out battery...
Good Luck
Feb 13, 2013 | HP Compaq nx9600 Notebook
When I charge my 12 volt car battery with my rac charger the amber light keeps flashing.
hi, the RAC battery charger is a british item, the amber lite could mean it is in a 2amp slow trickle charge, iam not positively sure. But here is the company website and phone# all lower case- helpline@kilka.co.uk - overseas phone # 020-8391-6767.
Hope this helps
Feb 09, 2013 | Cars & Trucks
Flashing LED on Samsung SBC-N1 Charger
LED flashing is unable to charge
Sep 05, 2009 | Samsung Cameras
Problem with extended battery
LED indicator for your laptop model
Steady Blue = Battery charged and AC adapter plugged in
Amber = Battery charging and AC adapter plugged in
Slow Amber Flash = <10% battery life
Fast amber flash = 3% remaining TPC will automatically go into hibernate
Slow flashing amber Adapter plugged in = Overheat condition
Do you have a multimeter to test the battery that you are using? check the output current of the battery.
May 29, 2009 | Motion Computing MOTION LE1600 Notebook
GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
Operation lamp - amber light blinking
I do not know the solution to your problem but I can tell you that when the camera is working properly that amber light means the flash is chargeing or your camera is doing something like saveing a picture so if your battery is low your flash might not charge properly or your camera might have something wrong with is memory. Sorry i couldn't be a better help.Good luck!
Sep 06, 2007 | Casio Exilim EX-S600 Digital Camera
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Cameras Logo
180 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
