Question about Wurlitzer Jukebox CD Player
Wurlitzer One More Time CD Jukebox
I have a weird sound problem which is only apparent on some tracks. E.g.... Sing baby sing will sound like Ssssssing baby sssssing, lyrics with a high frequency 's' are not crisp although not all tracks distort like this.I think this is called Sibilance. It is not the CD,s as tried them in a CD player and I have had the woofers re coned and tested. The distortion comes from the woofers not tweeters, it is annoying as the sound is otherwise perfect. Thanks for any help, Steve
  • 211 Answers
SOURCE: Wurlitzer 1015 OMT CD won't spin correctly
As far as I know the CD player for a machine of that age was a CDM 12. Your diagnosis is right but the same symptom can be caused by the control pcb underneath the cd player (you can see the led display to the right of the player. That's the control pcb). But generally it is the cd player itself.
However, you should also know that a similar thing happens when the laser eye is dirty from dust. But it doesn't sound like that to me. If it is dust the cd spins properly...stops....spins again....and then gets put back. If it spins as if it is having problems spinning it is usually the laser unit.
It's sensitive to static so touch any part of the metal of the jukebox that is definitely shiney metal to discharge yourself. To remove it you undo the four posi screws at each corner of the oblong unit. It's about the size of a large pack of cigarettes. Lift it up about an inch and you will see three plugs going into the sides. One on one side and two on the other. They just pull off with a bit of wiggling. (make a note where they go). While you are there take note that there are two loose metal spacers that the unit sits on, on the far two corners where the screws came out. They can easily get knocked off when you lift up the unit.
Transfer the black metal bracket piece on the top, to the other unit .....it's just two screws. And replace in the reverse order.
Make sure when you put the new unit back that you have the two metal spacers in place or it wont sit down correctly.
Have fun.
Dave F.
Posted on Nov 12, 2008
  • 211 Answers
I've just had a look at the link you posted. That's not the right unit. Electronically it is but not the base it is attached to is not for a Wurlitzer unit. It's a rock-ola (I think). If you are in the Uk contact Sound Sense Electronics. They will sort it out for you.
Dave F.
  • 211 Answers
SOURCE: Wurlitzer One-More-Time CD Jukebox can you get an adaptor to plug
Yes, you can buy an iPod docking bay and background music adaptor and play your iPod throught the jukebox. If a CD is played it over rides the iPod music until it has finished playing. It is called and iPod docking bay kit.
Dave F.
Posted on Jun 25, 2009
  • 195 Answers
SOURCE: missing CD player of Wurlitzer CD Jukebox model New York,NY 1993
All of the one more time jukeboxes used the Phillips CD player, they started with the CDM3 then the CDM4 and CDM12 etc.
Around 1993 it would have been the CDM3/4.
You need to identify which Decoder it is using in the jukebox or you need a kit that replaces the CD player and Decoder.
Regards
Alan Hood
ami-man
UK
Posted on Sep 07, 2009
  • 211 Answers
SOURCE: how do you connect an ipod to a wurlitzer cd
If it uses a K99 amp you can buy an iPod docking bay as a kit to fit to the juke. If it is a Compact I84 amp you can't.
Posted on May 26, 2010
Can't get the ipod to play through my Wurlitzer juke box although the attachment has been set up
Try putting another audio source into the BGM, the device inside the jukebox which switches it between the jukebox CD player and the IPOD. If you now have sound, check the IPOD docking station and cables. If you still have no sound, turn the delay time to minimum and try raising the level controls on the BGM unit. If you need further help, please email me, Rod Stebelton, tech@wurlitzer-ohio.com.
Dec 25, 2009 | Wurlitzer Jukebox CD Player
Stopping in the middle of a sing for about 10 seconds and then starts again
If it happens in the same place on the same CD is it the CD. If it is variable then clean the CDs and the laser eye.
Nov 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have a wurlitzer 'Manhatten'. How do I make it
The Manhattan is made by Sound Leisure of Leeds UK.
If this is the jukebox you have, you should be able to download a manual from their sites
www.soundleisure.com
www.classicjukeboxes.co.uk
Regards
Alan Hood
ami-man
UK
Nov 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Hello .Sometime does not play track
It is having trouble reading the CD.
Either....Dirty CD. Dirty laser eye. Duff CD. Duff laser unit.
One More Time does not like CDs made on your computer too.
Jul 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
How to track cd's.
What do you mean by tracking mode?
Dave F.
Mar 26, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Wurlitzer Jukebox CD Player Logo
69 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
