Aftron afwa1400 machine. Looking for a new drain pipe from the drum to the pump old one has split are they available in U.K.
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
SOURCE: washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . parts@appliancedesk.com ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
Posted on Dec 29, 2008
barkencoa
  • 3463 Answers
SOURCE: indesit 1060w leaking
It sounds like the pump or the pump inlet/outlet hose is leaking, more likely to be the pump.
Please rate my solution.
thanks.
Posted on Jul 24, 2009
SOURCE: Hi, good evening. I have a zanussi iz12 washing
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Posted on Aug 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: How to use AFTRON ( AFWA 55150) WASHING MACHINE
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
www.DIPLODOCS.com also has a large selection.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
Hoover H160E - stops with lights flashing 4 times (cyclic)... suaully before aspin cycle... appears to be incomplete drain (drains until no water viisble in drum - but still significant water at drain.....
I would definitely change the pump motor judging from your clear symptoms and observations!
It's probable that the motor isn't running efficiently, just enough when helped by the 'gravity' of the full drum but struggles once that is minimum.
Go for it ;-0)
John C
Feb 26, 2011 | Hoover H160E Front Load Washer
My washer won't drain, full of water with clothes
Check the pump for blockages. First unplug and drain the machine by hand as much as possible.You will have to tilt the machine to access the bottom of it. The pump will have an incoming water pipe from the drum, and an outgoing pipe to the drain. These pipes are usually fixed with spring clips which you press to release (may need a plier here). Remove the pipe that comes to the pump from the drum.Check for items blocking the pump via the opening for the pipe. You will probably find a sock or some other item blocking the pipe. Remove and re-fit the pipe and spring clip. It should work now.
Sep 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washing machine wont drain. it gets to the drain cycle and stops.
Sep 06, 2010 | Roper RAS6233KQ Top Load Washer
My washing machine will not drain at all unabling me to open the machine door as it is full with water, i have tryed putting it on a spin to drain however it the quantity of water in the machine just rose,...
Your pump is probably blocked. Do you have an outside area you can get the machine to? If so, drain it by taking the pipe off as described below:
Sep 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Kenmore washer stops after the wash cycle..will not drain or spin. I have checked the switch on the lid..what do I do next?
Sep 06, 2010 | Washing Machines
Drain hose is split - is it easy to replace or do I need an engineer?
so easy you will kick yourself. Tilt machine sideways and follow the pipe to where it connects to the drain pump. Remove the clamp and pull the pipe off. Once off, order a new one from an appliance shop. Its not imperrative if you put a pipe on from another machine but make sure the pipe end size is the same.(it must not be loose or the water will pour out when pumping)
Aug 05, 2010 | Bosch Washing Machines
Water leakage particularly when on full load. Machine is approx 9 years old. thanks
Could be main seal which is quite a large job, but advise looking inside could be a split drain hose to the pump, to access the inside, insert a flat blade 4" from each side between the front panel and the lid to release the clips. The lid will now hinge backwards, remove the 2 top screws on the inside of the front panel, this will now lift to remove. check the black hose at the rear of the drum to the pump.
Dec 13, 2009 | Admiral AW22 Top Load Washer
My Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Apr 19, 2009 | Indesit W 123 Front Load Washer
Indesit washer dryer 'omega 1200' WDG1295W won't drain!
Sounds like the pump is possibly faulty, or there is a blockage
There should be a removable plastic cover at the bottom front of the m/c, behind this you will see a round plastic cover.
This is the pump filter, unscreit and unblock it if it is full of ****!!!
Hopefully this should solve your problem.
Please leave feedback.
Dec 02, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
