Washing machine model-Aw-9000s.Main bord is not working
4 Suggested Answers
  • 385 Answers
SOURCE: My Roper washing machine model
Sounds like your agitator needs to have the agitator dogs replaced.If you take off the top of your agitator you can look down inside and see what's happening. Hope you find this helpful.
Posted on Jun 23, 2011
Testimonial: "Thanks! I didn't know it was so easy to take the cover off and see inside the agitator!"
  • 6277 Answers
SOURCE: My washing machine modle toshiba
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 27, 2011
SOURCE: Toshiba washing machine model aw-9771ubb error code e7-4
On washing machine error code e7_4 display and stop
Not working
Posted on Nov 10, 2016
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Not working
Nov 10, 2016 | Washing Machines
Washing machine aw 9770s
is this a stack washer and dryer . if it is it will be connected to a 240 volt supply and sounds like its only running at 120 volts check main power supply either fuse or breaker is not tied
Oct 19, 2013 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
I get an error F1 on this washing machine. What does this mean??
f1 means your rotor or main pc.b bord has a fault i would start by having the p.c.b control bord replaced there $ 120 in australia
Jun 21, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Maytag Neptune washing machine and washing cycle is not working properly. Please advise Derek
inspect thhe machine cotrol bord located in the consol behind the timer for burns look carefully ..if you find any replace the bord
Aug 09, 2009 | Indesit W 123 Front Load Washer
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to...
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Nov 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
