Question about Whirlpool LER5636P Electric Dryer
When I turn on the dryer it makes a sqealing noise. Belts seem ok.
    Sergeant:
  • 199 Answers
There are wheels that hold the drum in place they have berrings that tend to go bad i would replace them it should fix the squeek. also you can put some bar soap aon the beld to quite the squeek if it is not the holding wheels
Posted on Jul 21, 2009
Stering wheele fully turned it makes a screech noise and under hood it stops multiple pulleys but belts turn.
go to a mechanic, you have no knowledge it seems & your errors will only cost more to fix humbly speaking
Feb 08, 2015 | Cars & Trucks
Noise makes
if belt squeals , new belt time. (i drop off the belt and it goes silent)
if bet it ok, at at spec, tension then the alt is bad.
my trusty $5 harbor FRIGHT stethoscope, in ears, and i listen
sounds like box of rocks. bingo bad alt.
you make it so easy....
see here
http://www.fixkick.com/belts.html
or in the search box type, noise.
Dec 04, 2013 | 1995 Suzuki Sidekick
Make Frigidaire dryer model Gleq2152es1 is making a loud sqealing noise and the clothes getting hung in top of dryer.
mostly the noise your hearing is the drum running on the side of machine .the baering/bearings have collapsed in your drier . Most driers these days have the bearing encased in the outer drum and i mean molded to the outer drum . You cant replace them and the manufacturer doesn`t really want you to . Sorry about that = looks like a new drier for you .
Aug 13, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Steering making noise when turning steering wheel on ford focus
what kind of noise a loud squel noise or a poping noise
is sqeal check your fluid if fluid ok then the **** needs replaced
Aug 10, 2011 | Ford Focus Cars & Trucks
1998 mercury villager van , power steering belt was sqealing, so I replaced all three and it still sqeals and its still the power steering belt thats sqealing. I tried tightening it and that made the belt...
CHECK ALL THE PULLEYS WITH BELT OFF TO SEE IF ANY HAVE PLAY IN BEARINGS
OR ARE CONTAMINATED FROM PREVIOUS BELTS SLIPPING MAKE SURE THEY ALL ROTATE FREELY WITH NO SOUND
May 17, 2011 | 1998 Mercury Villager
Dryer sqeals very loudly during operation
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 07, 2011 | Frigidaire Dryers
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 02, 2010 | Maytag Dryers
Fluid leak and a sqealing noise when turning steering wheel,topped up with fluid and sqealing noise goes away?? but has returned and fluid level seems to be holding.
look to see if the pulley is coming off the pump and belt is going astray not lining up. also may have air in system jack front end up engine off and turn lock to lock with pump cap off look for air in pump may need assistint to look .
Aug 10, 2010 | 2005 Ford Focus
My maytag dryer is making a very loud noise near the area where the belts are, the belts seem to be working and the drum is turing, however after a while there is a burning smell.
Is the burning smell like plastic? If so read on. The belt runs on a spring steel plat tensioner with platic wheels of course. Plastic is on everything these days, huh? Well anyways the wheels the belt rides against has bushings inside them to make them last a long time which they do. It seems the plastic wheel will melt down in some spots and when rotating it makes the drum of the clothes dryer make a rumbling sound. I know you did not mention that problem although if the wheels keep on melting down the smell will subside but the noise will get loader as time goes on.
Jan 25, 2010 | Dryers
Dryer sqeaks cant open lid .Help.
a putty knife inserted about 2 inches from either side will release the lid spring catches
May 11, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
146 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
