Question about home Audio Players & Recorders
My home thiyeter dz590k is in power protection mode what i do?? please answer me fast its urgent.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
You apparently have a short somewhere in the speaker wiring.
Posted on Dec 19, 2016
Have a SONY DAV DZ370 Home theater system. Displays 'Push Power Protect'. Tried 'cold reset' and all the manual stuff to no avail. Should I reset the M16C micro-controller or is there...
Push power protect is an indication of an output failure ( Amplifier ). The Home theater system is asking you to switch off the power to prevent further damage. This mode is called protection mode and you will need professional help sort it out.
Aug 11, 2011 | Audio Players & Recorders
LAMP KEEP BLOWING OUT. TOSHIBA 65 HM167
I had this same problem with my Mitsubishi it is when you have fast on mode set it pre warms the bulb to much. I turneed it off and now the bulb has lasted much longer Setting the Power-On Mode feature You can select either Power-Saving or Fast mode. If you select Power-Saving mode and you turn off the TV, it can take several seconds for the picture to appear when you turn on the TV again. Power-Saving mode saves more power than Fast mode. See "Specifications" on page 66 for details. If you select Fast mode and the TV is turned off, the TV will stay in Standby mode for several minutes (see Note below). If the TV is turned on from Standby mode, the full picture appears immediately. To set the Power-On Mode feature: 1 Press Y and open the Setup menu. 2 Highlight Power-On Mode and press c. 3 Press b or B to select either Fast or Power-Saving and press T. Note: If Power-On Mode is set to Fast and you turn off the TV, the following will occur for a few minutes: • The screen (lamp) lights dimly; and • The fans continue to run. This is a function of the Power-On Fast Shutdown mode and is not a TV malfunction. If you do not prefer this, set the PowerOn Mode feature to Power-Saving. When the Power-On Mode feature is set to Power-Saving, if you repeatedly turn the TV on and off in a short period of time, the useful service life of the lamp may be shorter than the average useful service life (- page 63).
this is from your manual not my Mitsubishi please rate this answer if you felt it was useful.
Feb 03, 2011 | Toshiba Televison & Video
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Audio
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 21, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Every time I turn on my Onkyo receiver it goes in to protect mode.
Please check your speaker cables. Make sure that all of them are seated properly, none is touching each other or to the body of receiver.
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed speaker cable touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough to activate and it could blow a few trasistors in the power output circuit.
Please take out all the speaker cables, unplug your receiver from the mains and try to restart without any cables plugged. If it powers on then you are lucky.
If not and the receiver still goes into protect mode or wont turn on then it possible that there are bad connections on the main board or have some blown transistors. How old is your system? if its still under warranty then you should contact Onkyo immidiately.
Let me know if I can be of any further help. Please do rate this solution and thanks for using FixYa!
Mar 08, 2009 | Onkyo TX-SV727 Receiver
Need help with Media Player
WMP 11 will _ONLY_ install on a "genuine" copy of Windows. The only ways out of the "PROTECTION" error: * start in Safe Mode, and use System Restore to go "back" in time to a date before the problem started; * reinstall Windows from *GENUINE* media.
Dec 25, 2008 | Samsung HT-TX72 Theater System
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Bad speaker wiring.
Internal fault.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
Protection Problem on Samsung Digital Home Theater
Bad speaker wiring.
Internal fault.
Regards.
Apr 14, 2008 | Samsung HT-DS610 System
Need an urgent solution regarding "Protection" problem (I have a program to record in next 2 hours) pls pls help !!!
have suddenly getting a "Protection" message in Camera mode. - The viewfinder is OK and i can see the view but a "Protection!" message is blinking in the middle of the screen and the record button is not working if i press
Apr 13, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
46 people viewed this question
Top home Audio Players & Recorders Experts
Lawrence Oravetz
Johnny Massengill
Johnny Massengill
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
