My sgw 720 have problum this getting error e2 and no spin
Error 2 super general washing machine
I have super general washing machine model is sgw 620 this machine coming error E5
Oct 04, 2016 | General Washing Machines
Toshiba washing AW-9771UBB error code E2
i get Error code E2.. its stop working with out spin.
on Oct 18, 2016 | Washing Machines
Duet washer f9 e2 code
Hi, Switch power off. Remove plug from socket, wait awhile then restart, as if first time use. If error persists try to contact manufacturer. All the best.
Apr 17, 2014 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Singer 7258 error e2 when winding bobbin
I had this problem too. What I did was turn the post the bobbin sits on to the left (lefty-loosy) and kept re-booting the sewing machine until the bobbin started to spin correctly and the needle disengaged! I was so happy I figured it out, I did not want to return the sewing machine.
Nov 09, 2012 | Singer 7258 Sewing Machine
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at
Aug 30, 2009 | Amana Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
