Question about Krups Coffee Makers & Espresso Machines
Krups EA850B Loops after makking coffe betwen Machine adjustment in progress Machine filling in progress After pover cycle it finishes the operation and works again.
  • 39 Answers
SOURCE: it wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Posted on Dec 29, 2009
SOURCE: the hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Posted on Mar 19, 2010
SOURCE: hello, the spent coffe holder fill up with water
water fills spent coffee holder during coffee making
Posted on May 16, 2010
GodBlessU
  • 3513 Answers
SOURCE: Code error 06 in Krups
The error 06 comes after start up and machine in auto test - happens because of more than one problem. However first unplug the machine and then remove the water tank filter (the cylinder inside the water tank) and wash it up. Actually the filter should probably be replaced. However fix it back in the water tank and tide it safely upon the exit ring.
Now restart the machine and let it perform the automatic self testing.
Please get back to us if you have any further query.
Have a nice day.
Posted on Dec 08, 2010
Ironfist109
  • 3018 Answers
SOURCE: Krups coffe machine KM4065 does
Sounds to me like one or both of the Thermal Fuses are blow. This was the major malfunction for this coffee maker. Krups offers a three year full warranty on their coffee makers. So if this is still under warranty I would contact Krups and have them send you a new one or repair the one you have. Opening the coffee maker will void any warranty. I'm going to show you the steps on how to replace this and also a picture of what they look like. If you at all are not comfortable working with AC electronics. Find a trusted friend, family member or technician to do it for you.
  1. Unplug the unit.
  2. Remove the bottom of your coffee maker.
  3. The coffee maker has tamper proof triangle screws. You will need to acquire that style screwdriver. You can make the right sized flathead screwdriver work with enough messing with it.
  4. When you open the bottom the fuses will have a white sheath on them. ironfist109_21.jpg
  5. Slide the sheath it will look like this. ^^^^^^^^^ ^^^^^^^^^^ ^^^^^^^^
  6. The specks are on the fuses themselves. I think they are 216C and 240C
  7. Therm-O-Disc G4A01216C - Microtemp G4 Series, Axial Leaded
  8. Therm-O-Disc G4A01240C - Microtemp G4 Series, Axial Leaded
  9. and can be bought at http://www.goodmans.net/
  10. You may buy and extra one each in case this happens again.
  11. When you get the replacements and go to soldier them in you will want to put a couple alligator clips on the end of the fuse you are soldiering. This will act as a heat sink and protect the fuse from tripping.
Regards, Tony.
Posted on Mar 25, 2011
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
During a cleaning cycle my krupa ea8080 bean to cup machine started leaking water from underneath the machine. After trying to make a coffee once it had finished, some coffee is coming out correctly, but...
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Mar 26, 2011 | Krups Small Appliances Espresso Machine
Very little water comes through...small drips...enough to get the grounds wet but not enough to make coffee.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Krups Small Appliances Espresso Machine
I HAVE ALREADY FILLED OUT THIS ONCE.???WHAT MORE DO I NEED TO DO???? aLL I NEED TO KNOW IS DO YOU HAVE THE MANUAL FOR THIS MACHINE SO I CAN USE IT PROPERLY?????
Hello aandlolds!
Next time try add machine model number, this would help us know wich manual you need speificaly, anyways.. you can go to the Krups website to get the manual, only specify the family and model number, here is the website:
http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
you can try using this website too:
http://www.electrobest.com/krupinman.html
You can find any Krups coffe machine manual on those links !
Good Luck !!
Aug 13, 2010 | Krups Coffee Makers & Espresso Machines
I HAVE A EXPRESSO COFFE MACHINE MODEL XP4050
Just only I follow the instruction that I read in Fixya with citric acid and resolve my problem,
Thanks
Jan 14, 2009 | Krups Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
116 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
