Question about Electrical Supplies
I need the electrical drawings for a Perkins 1300 series generator with 7220 deep sea control
3 Suggested Answers
SOURCE: MY Perkins generator 2300 series crank but can not
2300 dce engine crank but not start
Posted on Jul 05, 2010
  • 8 Answers
SOURCE: What is the size Battery (cranking amp) needed for
Use a 120 amps battery
Posted on Jun 04, 2011
You have the remote control wires incorrectly connected either at the ATS or on the generator control panel, disconenct from both ends and ohm them to make sure they are not shorted between. Then reconnect them at the generator end only. Then join them together manually, of the gen starts and stops when taken apart, the problem is in the transer switch, or incorrect terminated
Jun 14, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Vertex 7500 not generate energy
Have you let it set for a long period? I have heard that if you do not use a generator that it will simply stop working(generator portion itself). Make sure no breakers are tripped and the wiring looks OK.
Sep 26, 2010 | Coleman Powermate Powermate 5000W...
What is the size Battery (cranking amp) needed for a 3990cc 4 cylinder Perkins 50HP AA Series Naturally Asperated Diesel Engine With a 40KW Generator attached. Thanks, Verner From Florida.
If the unit has a battery box, measure it and get the largest size that will fit and of course the correct voltage. Diesels take a lot to crank.
You can search battery sizes on the internet for physical size. NAPA has a pretty good selection.
Apr 02, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
My generator is not producing power runs fine does not make power
Could be several problems on the gen set itself. Check to see if there is a surge protection breaker or fuse, depending on age. Make sure all connecting wires are secure and switches are not set to 240v instead of 120v if you are trying to use outlets.
Jan 04, 2010 | Coleman Powermate Powermate 5000W...
Genset can not pick up once main electricity supply is off.
The controller circuit card needs to be replace. This is
the one that senses if and when power is shut off. This
will automatically start the engines.
Nov 03, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
