This is my second try and I don't think you understand my question. My small elec heater in my room won't turn on but the fan opens and no heat.
  • 14036 Answers
SOURCE: 1991 overheating Towncar
your pressure cap is used to maintain pressure in cooling system.over flow outlet is to let pressure off radiator when engine overheating.if clutch fan have resistance.its good long as the silicone oil isnt leaking from it.replace your thermostat.
Posted on Jun 04, 2009
  • 144 Answers
SOURCE: The OSD screen is up and won`t dissengage(after
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Posted on Mar 23, 2010
SOURCE: small Rival heater ... 1500
Heh, I just went searching for mine because it was getting cold. The left knob is (from left to right) Hi, Lo, and Fan Only. The right knob goes from Off on the bottom left to Hi on the right. It doesn't click or anything, since it's the one controlling how hot you want it to be.
Posted on Dec 12, 2010
  • 4736 Answers
SOURCE: Our Rinnai convector unflued room
According the the Owner's Manual for your Rinnai Convector Heater, there are 8 things, than can cause what you described. Two of which can be discounted, unless you just had the heater installed.
I have provided a link to the Owner's Manual, that you can download and print for future reference. Please pay close attention to Page # 6 -Pre-Service Check List and Fault Finding. Each problem listed has a troubleshooting solution.
Hope this helps you to further troubleshoot and solve the problem. Please let me know. Cheers!
Posted on Jun 17, 2011
  • 843 Answers
SOURCE: badger disposal has power, inside
When you turn it with the allen wrench, does it move a quarter turn fairly freely, then stop abruptly? If so there is something stuck in there. (Like a hard piece of bone, or glass but probably metal) Have a helper work the allen wrench while you look down in there with a nice bright light. On the other hand, if it moves a quarter turn but is very hard to turn for that quarter turn, then I am afraid you have some kind of fiber (string, fabric, or tendon) wrapped around the shaft where it would be very hard to get to. If that is the case, you might try removing and plugging the drain hose (that goes to the sink trap) and using some drain cleaner and letting it soak for a while --- but that is tricky because you will have to drain it out the hose wearing rubber gloves and full face protection. Good luck, Al K
Posted on Sep 01, 2011
I have a Big Maxx heater and it won't stop blowing and won't heat. The fan just keeps running! Anyone know what could be wrong?
Your pressure switch may not be activating (ie closing and making contacts) This means you could have a blocked flue, clogged pressure switch tube or a bad pressure switch. The pressure switch is a safety feature to ensure your exhaust is not blocked and operating correctly. Find owners manual. Look at trouble shooting section. Open cabinet and look for error code light. If blinking 3 times, try "jumping" the pressure switch. To jump pressure switch you need to clear code be turning off power. When the unit/thermostat calls for heat the power vent fan starts first, this is when you need to jump the pressure switch. You need to do this in sequence. That is the unit first starts the power vent exhaust thus activating the pressure switch allowing the ignition cycle to the burners and heat. So the power vent fan needs to start first BEFORE you put the jumper on to bypass the pressure switch. Once the jumper is on it will call for ignition after approx 30 seconds. If ignites your problem is one of the 3 stated at the opening of this paragraph
Mar 21, 2013 | Mr. Heater Natural Gas Garage Heater -...
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
I have no heat replace tthermostat,anitifreeze,the hose , I have good air cominng out of the vents last years I had a small bit of heat when I turn on the heat but this year none. what do you think It is?
Assuming the car does not overheat (Ruling out the water pump), I would look for something not opening the heater door. I think this car uses a pneumatic system to open the door for the fan to blow air over the heater core. If that door does not open, you won't get any heat. You probably have a cracked or broken pnuematic line behind the dash that controls the door.
Oct 26, 2012 | 1998 Mercury Grand Marquis
I do not have the manual to my fan forced heater (model HF-0034) and I am not sure how to work it. It keeps shutting off after a few seconds of heat. Then it will turn on again in 10 minutes and back off...
A lot of this, may be caused by the temperature setting and where the heater is placed. If the temperature is not set high enough, as opposed the ambient room temperature, it probably only turns ON briefly. Also, if the heater is placed near a heat source or in direct sun light, it's sensing the temperature from those sources, rather than the room air.
Try moving it to a another location and setting the temperature on the unit a bit higher.
Hope this helped you to solve the problem. Please let me know.
May 06, 2011 | Pelonis Heating & Cooling
Not staying lit
Remove the front panel and tape down the door safety switch so the unit can turn on when door is off. Turn up thermostat to make sure there is a call for heat. The circuit board should indicate a call for heat with either a blinking light or a solid light. Then the exhaust fan should turn on clearing the venting from any fumes. When the fan has ran for a few seconds, the igniter should start glowing orange. After it reaches a predetermined temperature, the gas valve should open with a click. The flame will start at the burner closest to the igniter and travel away from the igniter. There is a small flame rod located in the flame path on the last burner that tells the circuit board it feels the flame. If the flame goes off within a few seconds of starting, you have a dirty flame rod. Clean it with a scotch-brite pad. Once you get the flame to stay on for 90 seconds or so, the room air blower will turn on. If it tries 2 or 3 times to start but does not, the circuit board will record a code and display it with a blinking light. Look on the door panel for a wiring diagram. There will also be a Diagnostic chart that will tell you what the pattern of blinking lights represent.
Good Luck!
Nov 23, 2010 | Goodman GMS80453ANA Open Flame Mid-Size...
My Goodman air handler blower will not turn on when Thermostat is on auto fan. The blower comes on when themostat is set on fan-ON. The thermostat has be replaced, also the capacitor, and the BTDR. The...
Hello,Next is make sure the thermostat is set for ELECTRIC heat.In the back there is a dip switch or sometimes a small jumper that MUST be set to ELECTRIC setting.It will give a choice GAS/ELEC it needs to be set ELEC to bring on the BLOWER on a call for heat.It doese'nt matter if you have gas or oil or wood for fuel.
Nov 01, 2010 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
A solid red light
If you have the economy button on turn it off. If there is a draft around the room sensor it will read much lower than the room. That should make the heater run wide open all the time however. Make sure the screens and fan blades are spotless. When it is 4 degrees outside your heater may be working very hard to try to heat the room.
Stay warm,
Tom Hawkins
Jan 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Not enought heat
I have the same heater and it works great in my bedroom (with a door). the room is about 12 x 14. For my living room and dining area I use 2 or 3 oscillating, ceramic, fan forced heaters spaced out.
As you say, logically...since heat rises, the heat comes off the top. Only 3 things that I can think of would make that heater not work: First, a factory defect (it doesn't heat period). Second, if you have it a room that is too large for that size heater. Third, if the room has no doors (such as a living room).
If you have a draft it can work to your advantage. By placing the heater in line with the draft it will actually accelerate the heat exchange process and distribute the heat faster for you.
Dec 11, 2007 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
