Program to make jam - Office Equipment & Supplies
How do i install or remove any programs in Imate
You can download the file to your system, from the website, if you already have the program you can install with 2 procedures.
1. Normal Setup installation 2. .Cab Installation
1. For normal installation , you have to install Microsoft Active Sync 3.7 for your Imate Jam Normally the programmes comes for the imate having the setup files
How To install a program: Simply run the setup of the program you wish to install, make sure you phone is connected and active sync is running, Setup will run and it will ask you where you have to install the prog in Memory card or phone memory and you will see notification on your phone for installation
2. .Cab installation You copy the .cab file of any software into memory card and run the cab in your phone, it will ask you to install the program and just follow the on-screen instruction and you will be able to install the program in your phone.
You can get imate Jam software from the following websites Getjar.com gallery.mobile9.com
feel free to reply to this post if you require more assistance,
Regards, BA
Jan 15, 2011 | i-mate JAM Pocket PC
What program can i download to transfer music via bluetooth?
Please click on this link and use this software. I guess it would help you.
http://www.getjar.com/products/9583/EasySync
Regards
Sep 18, 2009 | i-mate JAM Pocket PC
Can't remove program from computer because task stopped during print task
you might have a print job in the spooler, right click on your printer icon, select open and right click on any jobs, and select delete.
Apr 19, 2009 | Office Equipment & Supplies
Printer will not print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet 3650 InkJet Printer
Password problem
You have to hard reset your kjam , and after it will work , but you will loose all your programs and data , if you have backup in your mem stick simply you can restore every thing
Apr 15, 2008 | i-mate K-jam Smartphone
Adobe Photoshop Album Starter edition 3.2
check that the driver is compatible and that the driver is not set to us or euro paper settings
Mar 31, 2008 | HP Photosmart 3210 Printer
Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
Eo-10 code
hi im jules_09,no the copier is not dirty or jammed,if there is a paper jam it will indicate paper jam there is no error code for that,if the copier is dirty you can see it in the print.reset the error code in the program,if the error code is still there checkfusing unit then the optic sensor
Nov 02, 2007 | Canon PC-940 Black and White Copier
19 people viewed this question
jasbo
jasbo
