Comparing one column value to four column values, then returning a name of company
SOURCE: count how many times a value appears in a column, based on anothe
Go to the cell you want this total in.
Type this formula:
=SUM(IF(Sheet2!C1:C10="EME",IF(Sheet2!N1:N10=1,1,0)))
make sure you end the formula with CTRL - SHIFT - ENTER which makes it an array formula. If you forget, go back to the cell with this formula and press F2 (to edit the cell) and press CTRL - SHIFT - ENTER to convert it to an array formula (Excel will show a little {...} around the formula).
Posted on Dec 26, 2008
SOURCE: Lifestyler c760 power supply values/specs
it is made by technical Devices
AC ADPTOR Model No. DV-1250
Input: 120 VAC 60Hz 12W
Output: 12VDC 500mA
Posted on Jun 28, 2009
SOURCE: Checking virtual IP servers... [VIP Raw]
[VIP Raw] TIMEOUT
Checking HTTP virtual IP servers...
[VIP Http] TIMEOUT
Posted on Mar 25, 2010
  • 3015 Answers
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
Posted on Aug 18, 2010
  • 2291 Answers
SOURCE: not able to sign into messenger and receiving this
Clickthe "Messenger" menu in Yahoo! Messenger and select "ConnectionPreferences." 2.Enable the "No network detection" option and then click the"OK" button at the bottom of the window. 3.Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the "OK" button. 4.Enter your Yahoo! ID and password and click the "Sign In" button. youmay have a registry problem download registry cleaner reginout to fix the issue
Posted on Mar 01, 2011
Vlookup for duplicate cell values to display both names in separate cells
Check your formulae for a small error. Use F1 to guide you.
Jul 14, 2017 | The Computers & Internet
Tip
Dreamweaver Thought that Teaches You, to search a database with phpmysql...
OK, this should work... First of all, there is one great extension for DW & PHP ADOB object model that is free and great! Download it and install from www.interakt.ro its called PHAKT (NOT impakt, because its not free).
Install it and you will have another type of PHP ADOB document type.
Start project with PHP ADOB (not old PHP MYSQL).
Page 1
Create form that has come Editbox and one button. Name Edit box something like e.g. "Search" without quotes.
That form should have form action="results.php" and type set to POST NOT, Create Page 2 and name it results.php.
Create new recordset in dw like this
SELECT "
FROM table WHERE table.column.you.r.searching LIKE '%colname%' OR table.other.column LIKE '%colname%' ORDER BY table.tableid this means that we want to select ALL (*) records in table WHERE content of column is similar (Dav, will return Dave, David, Davidof...) to search keyword.
Next, in variables click + and add variable name colname default value set to % if you want to show all records if form is submited blank, or -1 if You want to show none if form is submited blank. Finaly for Run-time value type $HTTP_POST_VARS['search'] Runtime value is equal name of Edit box name you set up in first page...
Now, from bindings tab, select values and insert it on page, that You would like to show on page. Ill skip this part assuming You know how to format output and how to limit it but if you dont know ask in reply...
So now You have page with results. Test it and see if its working.
If it is, create page 3 and name it details.php. Now, select value from page that you want to link with details page and click on link. Select details.php page and click on parameters. For param name enter something like id since this should be PK in table and unique value, and for value click on lightning icon, and select primary key in your table. In live page link should be like details.php?id=<some_value>.
As for details page recordset it should look like
SELECT *
FROM table
WHERE table.id = 'colname'
create vars as for page 2, but change Runtime to $HTTP_GET_VARS['id']
and format output on page. That should be it, but since im typing it in "realtime" maby i forgot something...
Home I did helped You.
on Jan 21, 2010 | Computers & Internet
Sum numbers in a column down until you come to a blank, then start again
Sounds like your issue can be solved readily with a pivot table.
If you give the columns of names a title like "NAME" and the number columns a name like "VALUE". All other columns should contain a unique name.
Then select the entire table, including the labels at the top ensuring that the range extends entirely over the column you need to sum the values of.
In Excel 2013, choose the INSERT menu and select the PIVOT TABLE command.
Insert the Pivot table into a new worksheet.
A new sheet will open with a strange-looking control panel on the right of the window.
Make sure that the box for NAME and VALUE (only) are checked
You will notice that Excel assumes that you want the SUM of the values for each NAME summed. The results are in the leftmost area of the worksheet.
If this works for you, please vote my answer as "helpful".
Sep 03, 2014 | Microsoft Excel for PC
Plz tell me Sir/Madam. what is Hlookup And give me example
Hi Geetad11
This is Horizontal lookup , used to look up value in a 2 dimensional table .It searches for a value in the top row of a table or an array of values, and then returns a value in the same column from a row you specify in the table or array. Use HLOOKUP when your comparison values are located in a row across the top of a table of data, and you want to look down a specified number of rows. The H in HLOOKUP stands for "Horizontal."
Formulae Syntax
HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)
Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string.
Table_array is a table of information in which data is looked up. Use a reference to a range or a range name.
  • The values in the first row of table_array can be text, numbers, or logical values.
  • If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted.
  • Uppercase and lowercase text are equivalent.
  • You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
Row_index_num is the row number in table_array from which the matching value will be returned. A row_index_num of 1 returns the first row value in table_array, a row_index_num of 2 returns the second row value in table_array, and so on. If row_index_num is less than 1, HLOOKUP returns the #VALUE! error value; if row_index_num is greater than the number of rows on table_array, HLOOKUP returns the #REF! error value.
Range_lookup is a logical value that specifies whether you want HLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, HLOOKUP will find an exact match. If one is not found, the error value #N/A is returned.
Remarks
  • If HLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than lookup_value.
  • If lookup_value is smaller than the smallest value in the first row of table_array, HLOOKUP returns the #N/A error value.
Example
The example may be easier to understand if you copy it to a blank worksheet.ramsoft.jpg
Oct 06, 2010 | Microsoft Excel for PC
Hello i want to use h LOOK UP
Hi !!
How to implement Hlookup function:
  • Select your data and sort it in ascending order
  • Then type '=HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)'.
    Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string. Table_array is a table of information in which data is looked up. Use a reference to a range or a range name. The values in the first row of table_array can be text, numbers, or logical values. If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value.
    If range_lookup is FALSE, table_array does not need to be sorted. Uppercase and lowercase text are equivalent. You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options in the sort dialog box, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
  • If range_lookup is FALSE and lookup_value is text, you can use the wildcard characters, question mark (?) and asterisk (*), in lookup_value. A question mark matches any single character; an asterisk matches any sequence of characters. If you want to find an actual question mark or asterisk, type a tilde (~) before the character.
  • In the example in the Excel training video the sorted data represents the density of water at different temperatures. The left most column gives the temperature in degrees and the top column specifies the 'decimal' degrees
  • We looked up the density of water at 5.4 degrees celsius using the Hlookupfunction.
Still have problems, Check this video on the you tube.
Hope this would help,
Thanks,
Anurag Shukla
Sep 04, 2009 | Microsoft Excel for PC
How to get printer state reasons linux (Paper tray is empty)
Try using a PPD from mac OS. make sure cups is up to date.
Apr 27, 2009 | Canon imageRUNNER 330 Printer
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
More than 256 characters in a cell in Excel
If a RANGES
\r\n
Named Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\nWorking With Ranges. FindLast cell/row/column etc.
\r\nFormula Reference Changer. Absolute to Relative etc.
\r\nSpecialCells Method
\r\nExcel Named Range Manager $
\r\nOFFSET RANGES VBA
\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\nexpression.Offset(RowOffset, ColumnOffset)
\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\nExample
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\nEnd Sub
\r\nIs the SAME as;
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\nEnd Sub
\r\nOFFSET FORMULA
\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\nExamples
\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
May 16, 2008 | Microsoft Excel for PC
Lookup,s
If you can move your name column (C) to the first column, you could leverage the VLOOKUP formula pretty easily.
To do this, do the following:
1) Move the C Column to be the A Column, shifting all other columns to the right.
2) (optional) Insert a new row at the top of the sheet (to hold the formula & seach value)
3) Use A1 as your search field.
4) In A2, enter the following formula:
=VLOOKUP($A$1,$A$2:$C$6,3,)
Describing above parameters, in the formula:
$A$1 -> the search field (name your looking for).
$A$2:$C$6 -> The table/grid you wish to search and return values from. The left most column (A) must contain the values to be searched.
3 -> is the column number (A=1,B=2,C=3, etc) within the table/grid to return.
If you cannot make the name column your first (A) column, there are more complex ways to do this. For instance, create a new sheet which redisplays the info in the structure easier for this method, and perform the VLOOKUP on that data. Other options might exist in creating a complex formula that would get you what you want.
Also, if you can sort column A (names) it would find results faster, if your data set is large.
Feb 03, 2008 | Microsoft Excel for PC
Function
VLOOKUP is to Searches for a value in the leftmost column of a table, and then returns a value in the same row from a column you specify in the table. Use VLOOKUP instead of HLOOKUP when your comparison values are located in a column to the left of the data you want to find. The V in VLOOKUP stands for "Vertical." Syntax VLOOKUP(lookup_value,table_array,col_index_num,range_lookup) Lookup_value is the value to be found in the first column of the array. Lookup_value can be a value, a reference, or a text string. Table_array is the table of information in which data is looked up. Use a reference to a range or a range name, such as Database or List. If range_lookup is TRUE, the values in the first column of table_array must be placed in ascending order: ..., -2, -1, 0, 1, 2, ..., A-Z, FALSE, TRUE; otherwise VLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted. You can put the values in ascending order by choosing the Sort command from the Data menu and selecting Ascending. The values in the first column of table_array can be text, numbers, or logical values. Uppercase and lowercase text are equivalent. Col_index_num is the column number in table_array from which the matching value must be returned. A col_index_num of 1 returns the value in the first column in table_array; a col_index_num of 2 returns the value in the second column in table_array, and so on. If col_index_num is less than 1, VLOOKUP returns the #VALUE! error value; if col_index_num is greater than the number of columns in table_array, VLOOKUP returns the #REF! error value. Range_lookup is a logical value that specifies whether you want VLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, VLOOKUP will find an exact match. If one is not found, the error value #N/A is returned. Remarks If VLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than or equal to lookup_value. If lookup_value is smaller than the smallest value in the first column of table_array, VLOOKUP returns the #N/A error value. If VLOOKUP can't find lookup_value, and range_lookup is FALSE, VLOOKUP returns the #N/A value.
Aug 30, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
