Why can't I tell whether my sub-woofer is working. Listening closely I'm not sure if I am hearing anything. All other speakers5 work and effect lights it to say that it is on? Terry.
hawkwatcher
  • 67 Answers
SOURCE: sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact kstahl65@att.net for details
Posted on Jan 10, 2008
SOURCE: Sub Woofer Won't Work
mbruno did this work? I have the same issue
Posted on Jan 16, 2008
  • 86 Answers
SOURCE: SONY STR-DG510 Sub woofer does not work
You will need a powered sub because your receiver does not amplify in the sub output.
Posted on Jan 21, 2008
  • 979 Answers
SOURCE: Eltax DR-110 Sub-woofer issue
Where have you connected the sub's leads?
Posted on Feb 29, 2008
SOURCE: sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
Posted on Nov 21, 2008
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Sub woofer is not working. it has orange flashing light at the back
Look at the connection of the sub woofer. The orange light indicates either there is some problem with the wire or the connector at the end of the wire.
Also make sure the pin or hole where you insert the sub woofer is working perfectly. You can simply check it by placing another sub woofer at that vary spot and see if it is working fine. If the hole is fine then the problem is either with your cord or your wire pin.
Oct 24, 2012 | Audio Players & Recorders
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
My SONY Home Theater Model HT-6600DP unit was working fine and then about tow years after...present, my sub woofer is sounding distorted. Why is this happening? Please help me as I often watch my home...
Is it so even at lower volumes?
Are you sure it's the sub distorting and not the front or center speakers?
If you designate them incorrectly as Large (which tells the receiver they CAN effectively produce bass frequencies) they will probably distort in the presence of low frequencies.
See Page 17, 19
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-HT-6600DP-Home-Theater-Systems-manual/id/390ag319/t/2/
Mar 13, 2011 | Sony HT-6600DP System
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to www.speakerworks.com and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
Feb 07, 2011 | 2001 Toyota Sequoia
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Do you know if my woofer is blown?
well if you hear a rattle sound its probably already blown...and the amp could be drawing too much power if the radio shuts off...make sure all your wiring is correct. also if your car is off and you turn it up it will most likely shut off cause the battery cant handle it. but as for the sub i think its blown. good luck
Nov 16, 2008 | Jl Audio 12W3 Car Subwoofer
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
24 people viewed this question
 Grubhead
Grubhead
