Question about Makita Drills
Battery charger shuts off when you put in a battery to be charged,reset wont work,unit is getting warm-a Short ?
I have this problem with my black and decker when I tested the leads in the charger they have power, I tried 3 different batteries. I took the charger apart and plugged in the battery, this is when I noticed the 10v + power that I was getting when testing just the charger turned off when the battery was installed, so instead of reading 10v from the charger I was only reading 4v of the dying battery. I removed some covering only to find the resistor burnt black, and the led light with black in it. I am guessing that I could replace the resistor and light if I could tell what kind they were.
Posted on Jul 30, 2009
How do i charge the battery on a 1992 honda shadow vlx 600c
First check the battery voltage using a multi-meter set to DC and volt range if reading is below 12V battery has probably one dead cell get a new one, if between 12v and 13V battery should be OK to charge. Remove battery undo negative lead first then positive. Please do not use a car charger or any other charging device that has an output greater that 1 Amp you will fry the battery. Charge the battery for as long as possible. Recheck volts across the battery if above 13V refit battery connect positive lead first then negative.
Start your engine, when warmed up check the voltage across the battery terminals it should be well above 13 volts. Increase the revs and watch the meter the voltage should increase to about 14.5 volts. This shows the battery is being charged. Please remember batteries on bikes only last a few years and short rides do not put enough charge in your battery. Buying and using a motorcycle Smart charger does help. I use a CTEK XS 0.8 12V Motorbike Battery Smart Charger & Conditioner. You get a small wiring harness that fits to the battery with a rubber connector that connects to the chargers plug. This unit will help to keep the charge in the battery topped up.
Jan 10, 2015 | Honda Motorcycles
Why wont my dirt devil gator 18v charge?
Hello! If you are experiencing a short run time your battery may need to be reset. Try completely depleting the battery. Run the vacuum until it shuts off. Then re-charge for a full 24 hours. The indicator light will come on to indicate the unit is charging. If there is no indicator light on the charger, the charger may need to be replaced. Below is a link where you may go to purchase the charger if needed. Hope this helps!
Charger Innsbruck 1100Mah 1300Mah Cec 2013 Compliant
May 12, 2014 | Dirt Devil Dd Gator 18v Cordless Hand Vac
HP 584037 battery not charging anymore, the yellow light turns white or switch off after just 20s - and the PC does not work either just with the charger. Still , the charger delivers normal tension -...
sometimes you can take the battery out and put it back in (Re-seat Battery) or the cord on chrger could be broken inside near the plug some computers wont recognize and deactivate charging if there is a short in the charger could just be the battery is bad if it has been progressively getting worse
Jan 01, 2014 | Computers & Internet
Samsung galaxys 2 drain battery fast
The power cell should only get warm if you have it powered on all of the time. That is natural. 6 hours is short, and that may be one of two problems, the time of charge is too short, or the battery is dying. HINT! If you replace with a NEW battery; you must set the battery memory for the start. That means, when you first charge it, make certain it gets a long 24 hour charge to full. Use the phone until the device shuts down because the battery was exhausted. Now Do a full long term Charge. That process will set a Memory for the Power Cell and allow you to fully charge and discharge the battery from there on. One more thing...if you use a Charger Device, make certain it is working OK or else the Battery will not charge well.
Dec 12, 2013 | Samsung Galaxy Tab 2 7.0
My Sony Viao wont stay charged and when i try to power it up, it shuts down by itself at the sign in screen. It wont let me get past the sign in screen,
Are you using a Sony Battery or an aftermarket cheaper version?
If your battery has been changed to a different brand then thats your problem and a whole problem in itself.Not saying there is anything wrong with that, but the Sony ISBmngr.exe file will stop the charging of any battery exept Sony's and put the system into hibernation mode. ( website with Info below)....
If you have the original manufacturers battery then go on.
This is the typical charging-plug, jack, for laptops. Many times the plug itself is bumped over time and pushes on the pin in the center. The charging time becomes very short, if at all, because the connection is broken.Some are completely or because of the position of the wire holding it just right long enough to give a short charge.
32917b9.png With a Voltmeter ,check the output of the charger itself to be sure it is working properly.
Although VIAO has been out for a while & because the model was not listed here the age of the battery may also be in question. If the battery has shorted out and the charging unit & jack are fine then a bad battery that has shorted will cause you symptoms also. Try removing the battery and running on the charger alone.
Here are a couple of sites that I found that deal with Sony VIAO's
1. http://www.ghacks.net/2008/02/02/sorry-you-cannot-use-that-battery-because-it-is-not-made-by-us/
2. http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
3. http://sarabannerman.blogspot.com/2007/04/sony-laptop-battery-mal-ware.html
Oct 04, 2010 | Sony VAIO VGN-CR220E/P Notebook
My cell get heated when i put charge batt chg circuit of cell isnot functioning i get batt chg from universal charger nokia1100
Usually it is the battery hat is becoming old enough to internally short and this will cause it to work poorly and not ever fully charge, and get warmer than normal or hot when attempting to charge for more than 1/2 hour. Sometimes the chargr can go bad and over charge, thus making the battery too warm. if you have a car cell phone charger that plugs into cigarette lighter outlet , you can atach this and see if battery gets too warm, but these chargers usually charge faster than electric plug-in type, so expect some warmth within 20 minutes, but again if too warm than you know itis the battery. For these unnits batteries are not expensive.
Apr 28, 2010 | Nokia 1100
Fully charged put on cradle fatal alert/fatal exception/reset
the lightning bolt is normal ..its telling you the battery is being charged .. if you get an error code or if the unit quits working then you can do a reset or a "hard reset" ... the hard reset erases everything and will restore the unit to factory conditions .. to do a reset .. unscrew the top of the stylus .. that gives you a probe to push the reset button on the back (top) .. if you hold the power button in while you do a reset then it gives you a choice to "erase everything" .. if you accept then thats a hard reset ... if everything else fails .. do a hard reset .. you can do all this while its on the charger so if you have a bad battery that wont matter .. if the battery wont hold a charge then it can be replaced ..
Sep 03, 2009 | Palm m515 Handheld
Garmin 260 now failing to charge and shuts itself down
If the unit is only a year old? then I would suspect that the charger has a problem that has damaged your battery. Do you use an external power continuously?
Try a different charger or if you have a meter make sure the charger is putting out close to the specs on it. Try using the usb cable to charge it.
The low battery and shutting off are typical of a battery that won't/can't hold a charge. That is typical after 2-3 years plus but not one year. It can also be indicitive of the charging circuit needing to be reset. The problem is it needs to be started and run long enough for it to recognize the reset command. To do this, hold your finger on the bottom right corner of the screen while powering the unit, until it asks if you want to reset it. That might get you running.
While I would be suprised at the battery going out within a year or so it is not unheard of. You may have to replace the internal battery pack. The unit is new enough your only source is probablly going to be Garmin. They might replace the battery under warrenty or out (if you talk nice).
Jul 24, 2009 | Garmin nuvi 205 GPS Receiver
Dewalt battery 18 volt
How old is the battery? They do die if old and well used! You can try checking the fuse inside the charging unit . If this does not work or fuse is OK you can get the battery revived (there are places that do this) if it is not completely stuffed or just get a new battery which are quite cheep on ebay
Sep 10, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
Drills Logo
235 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
