Question about Sharp Office Equipment & Supplies
Reset code sharp ar-m258 - Sharp Office Equipment & Supplies
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
  • 990 Answers
SOURCE: sharp AR-R550n
Hello sir; You may try to perform a reset procedure as follow;
press " program", " * ", " clear ", " * " and start key, then enter 17, press start again, turn machine off and back on.
Posted on Aug 23, 2009
SOURCE: Sharp AR-163 Copier, How to Reset/Solve the error
how to clear red sing on tonal problem for sharp ar 163
Posted on Sep 19, 2011
Error H4 00
This problem occurs in the Sharp copiers. Therefore pls check the fuser lamp (heater lamp) To reset this error code I need the machine model no correctly.
Feb 10, 2014 | Toshiba Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M258 error code u2-40
l have sharp print Ar m-258
i want print front no extra
how is change setting
but show massage
(Load Extra Paper into Bypass -type(Type plan)
Apr 13, 2012 | Sharp Office Equipment & Supplies
Sharp AR-M258 Error Code H4-20
If any one faces error H4 problem on sharp AR 258
press fast the below keys and 99.9% on the case will be solved.
1. Press #, interrupt, c, interrupt or Press #, * ,C, *
2. Enter 14, press start
wait for few seconds and it will work
Mar 22, 2011 | Cameras
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Jan 20, 2010 | Sharp AR-M208N Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
