Question about Frigidaire Dishwashers
What cause the lock light to come on on a Frigidaire dishwasher
Have a frigidaire dishwasher number FFBD2406NS, has power to the washer it self but none of the lights turn on once pushed to lock the door.
Good Afternoon Billy, thanks for your submission!
I understand that your Frigidaire dishwasher, FFBD2406NS, is receiving power but no lights work once the door has been closed and locked. There could be an issue within a wiring harness, door lock, or control panel. Since it could be anyone of these underlying issues I would suggest having a professional technician to perform a proper diagnosis. This will prevent you from purchasing any unnecessary parts. Hopefully this information is helpful towards your repair. -Matt
Mar 21, 2016 | Frigidaire Dishwashers
24" builtin Frigidaire Dishwasher, light on top of door says, Hold to lock. I can not operate the machine while this lite is on.?
Hello Ray E. Weaver - Sounds like the Child Lock option may have been selected. This is a safety feature that allows you to lock and unlock the controls to keep children from interfering with the wash cycle etc. Press and hold the AIR DRY pad button for 3 seconds while the door is latched. This should unlock the control pad for you, light goes out and the unit will display the last cycle ran. However, if it does not, try resetting the unit by unplugging it for flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. However, if it proves to be ineffective I recommend contacting a professional to assist further. The dishwasher may possibly have faulty door lock switch.
Apr 03, 2013 | Frigidaire Dishwashers
Frigidaire Dishwasher - Not starting
If you press and hold the button above the lock icon for 3-5 seconds,the lock light should go off. Then it will operate normally..hope that helps
Feb 24, 2018 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher won't work heat lock light on how do
some dishwashers have a "lock out" mode so kids don't accidentally turn on. Normally, by pressing and holding the button for 5 seconds, it should turn it off.
Apr 07, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
The panel of my frigidaire dishwasher has a dummy light signifying a lock. it will not respond to any other button
to lock this unit out you have to hold the lock button down for a few seconds until lock light comes on. lock button could also be a combination button with start button or some other button. hope this helps!
Aug 29, 2009 | Frigidaire Dishwashers
I have a Frigidaire built in dishwasher that won't start. There is a light on by the 3 second lock button
Your dishwasher is in the lock mode. If you press the button on the dishwasher that has the lock for maybe 5 seconds , the light will go off. Then put the dishwasher in a wash cycle (normal) and your dishwasher should start up working. Make sure the door is all the way closed. Hear the click of the door when it shuts. After about 90 seconds it should have water in it, press the start/cancel button 2 times and the water drains out.
Jul 30, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Lock light is on
The lock only locks the buttons (childproof), hold it 3 seconds and it will go out.
Jan 18, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
