Question about Kitchen Ranges
My oven right rear burner came on hot by itself with no lights indicating it was on and nothing would turn it down or off?
  • 473 Answers
SOURCE: burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Posted on Oct 09, 2007
  • 23 Answers
SOURCE: GE Spectra range
All of the items you mention that do work, are 120 volt items.
All the items that do NOT work are 220 volt items.
Sounds like you have a voltage problem, you will need to use a meter to check if you have 220 volts a/c to the outlet the stove plugs into. Take care when doing the following, you will be around live voltage and could get hurt. If you are uncomfortable working with a live circuit best to call someone in to do it for you. Check for 220v at the outlet for the stove (where the stove plugs into), if you have it there, go to where the cord attaches to the stove and check at that point. You should have either a 3 or 4 wire cord on the stove, On the rear of the stove there is a terminal block that the cord is fastened to. Between RED and BLACK you should have 220v, between RED and WHITE and BLACK and WHITE you should see 120v. Another thing to check is that the nuts holding the wires from the cord to the terminal block on the stove are turned down tight. A loose connection there will give you the same problem you have as well.
Posted on Feb 19, 2008
  • 126 Answers
SOURCE: Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Posted on Jan 15, 2009
  • 1304 Answers
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Posted on Oct 21, 2009
SOURCE: Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Posted on Mar 18, 2010
Gas oven heats up to proper temperature and then quits heating.
It sounds like you may have a Whirlpool gas range. If so it is more that likely the burner assembly itself. The electrode attached to the burner gets to where it will light during the preheat but then once it starts to cycle the spark module tries three times to light the burner and then shuts down. the burner assembly comes as one unit with the electrode attached.
Nov 28, 2013 | Ovens
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
The light for the right back burner stays on,even though the burner is turned off and is cool
Dec 25, 2010 | Microwave Ovens
Hot indicator surface light will not turn off on maytag smooth top oven cre9600bce. always stays red even when oven or cook top not in use. What part is needed.
I had the same problem, but I found out it was only when one particular burner was turned on. I waited for the problem burner to cool, then took the fist of my hand and tapped on the burner itself and the light goes out every time. Works like a charm..probably a loose connection with that one burner.
Jan 30, 2010 | Kitchen Ranges
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
I have a new ge range. When I turn on the left
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
Apr 11, 2009 | GE Kitchen Ranges
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
