Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
I think my mother board is fried.
I recently received internet service that did not work. When I called the technician that worked for the ISP he troubleshooted me through some things which included plugging in a usb cord to the modem. The laptop made a popping sound and it shut off. Now it does not want to turn on. When I plug in the charger, the charge light turns on but nothing else.
  • Chris
    Chris May 11, 2010
    I don't see a question here, you simply describe that your ISP tech support instructed you do do something which damaged your laptop and then arrived at the most likely conclusion that your motherboard is in fact fried.
    Scholar:
  • 119 Answers
If they had you plug in a USB cable to the modem (not even sure how that fit) then you need to work through the ISP to repair your laptop.
The battery probably is charging but sounds like the mobo is fried (like you suspect).
Posted on Jul 21, 2009
    Scholar:
  • 151 Answers
If you need another motherboard then i wouldn't bother, i would just buy a new pc for the price it will cost to replace the motherboard.
Regards
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
My Whirlpool Cabrio electric dryer model number WED6400SWI was not heating the air to dry my clothes, everything else was working normally. I had read all possible causes but called in a technician as I...
Unfortunately in the service world there are both unskilled and dishonest people. However, I would first call the service company and complain of the poor service, second call the #800 for service and complain about the service company they sent out. Third, the problem may originally been something as simple as a clogged vent. Did the dryer run feel warm/humid when you opened the door, buy clothes were still wet?
Aug 14, 2013 | Whirlpool Dryers
Ps3 wont sign into online servers
is there an error code?
do you have internet service?
do you have a ps3?
whats your mothers maden name?
try bi-passing your router and connecting directly to the ISPs modem. does it work now? if so call the ISP and tell them you want to put your modem in bridge mode.
Aug 14, 2012 | NetGear WGR614 Wireless Router
TOSHIBA NB255 FORGOT PASSWORD BLUE BOX WONT DO ANYTHING I THINK MY WIFE CHANGED IT BECAUSE I ALWAYS USE THE SAME PASSWORD FOR EVERYTHING BUT NOW IT WONT WORK
Easy solution but sometimes hard to do because of close quarters.What you need to do is locate the watch battery inside of the lap top.It may be under one of the back panels but not all ways.If you have to open the case it is super easy to break something and some will only open an inch because of a small electric ribbon hooked to the top board.What you do is remove the watch battery for ten minutes and then put it back in.Be sure and ground your self by touching the metal frame because if you have any static electricity and it jumps to the mother board it will fry the motherboard.If your not handy with delicate work I would take it to a technician. Good Luck. Easy solution but sometimes hard to do because of close quarters.What you need to do is locate the watch battery inside of the lap top.It may be under one of the back panels but not all ways.If you have to open the case it is super easy to break something and some will only open an inch because of a small electric ribbon hooked to the top board.What you do is remove the watch battery for ten minutes and then put it back in.Be sure and ground your self by touching the metal frame because if you have any static electricity and it jumps to the mother board it will fry the motherboard.If your not handy with delicate work I would take it to a technician. Good Luck.
May 18, 2011 | Toshiba NB255 Netbook
My old outdated emac wont connect to internet
A lot of people think its the computer when they can't connect to the internet. In reality it's most likely your Internet Service Provider (ISP)
Check the lights on the front of the Cable modem or DSL modem. The "received" light is the one you need to worry about, if it blinking it's receiving data.
If you are not seeing any blinking light you will need to call your ISP for troubleshooting.
A lot of times they do maintenance and have disconnect everyone in the area.
Sep 17, 2010 | Apple eMac G4 Desktop
My internet connection does not work. I can't connect to internet. My modem blinks but it seems it can not find anything to connect to it. It used to work for a few months but suddenly without any reason...
turn the computer off and unplug the modem for few seconds (15) then reconect the modem and let it start all the lights
about (20s) then turn the computer on.
if still cannot connect call your ISP
Aug 20, 2010 | Arris SURFboard SB5120 Modem
Is there anywhere to buy component parts ?
New, original parts - probably not. IBM usually will only sell to their authorized service centers and technicians. You may be able to find used parts on eBay. Make sure you are getting the EXACT same replacement part - the wrong power supply can result in a fried mother board.
Jan 04, 2010 | IBM ThinkPad A30 2652 Notebook
Internet wont go thru to the the xbox 360
well first of all is it your internet , call the ISP ( internet service provider) and ask them if you have the right speed for xbox maybe they lowered you . If its not that then go to the settings on the xbox click on the network settings i think its called and make sure its set on def. if not do it manually fill in all the numbers req'rd such as ip address what ever you don't know find out from your isp . when you make a new connection on your xbox it should work , if not then your xbox is fried .Call the 1800 number and they will tell you to send it in , you get 3 months free xbox live and a new xbox !!
Mar 31, 2009 | Video Game Consoles & Games
Will not power on any more, it's dead.
Check the power cable and wall socket. One of them is likely the problem. If not, it could be that the power board on your TV has failed. In this case, you will have to get a technician to diagnose and repair the fault.
May 25, 2008 | Mitsubishi WS-65807 65" Rear Projection...
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
125 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
