I have a kelvinator ksc25e but after about 5 minutes, the fan on the outside unit stops. Will still blow cool air inside, then 5 mins later it will start again. Will keep repeating over and over.
  • 575 Answers
Could be the thermostat, fan motor or a capacitor. Check each one. Check if the fan and the compressor go on together. Check if the fan blades move freely. Check continuity on the capacitor.
Posted on Dec 19, 2016
2 Suggested Answers
  • 140 Answers
SOURCE: air conditioner not geting cool
Hello, It sounds to me like your low on freon/refrigerant. You'll need to have someone test the pressures for you.
Posted on Jan 24, 2009
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
I have a kelvinator ksr25f split system.The green light on the front panel flashes when the unit is turned on.The unit cools ok and when the temp is cool enough the outside unit stops as normal but doesnt...
Check and make sure the outside fan is running. The KSR series Kelvinators were rebadged LG units. It is possible the 6uf fan capacitor on the outside unit has failed.
Mar 04, 2014 | Heating & Cooling
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
My inside and outside unit turn on fine, out side fan and compressor running good,inside blowing cool air, about four minutes after that, out side unit shutoff, no humming, nothing.
Are you heating or cooling? When the outdoor unit shuts off how does it come back on. Or are you saying that the outdoor unit is short cycling off and on
Jan 17, 2018 | Ruud Heating & Cooling
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
Outside unit trips the circuit breaker
seems that if it runs for 5 minutes there shouldnt be any shorted wires I would say your breaker needs replaced
Aug 04, 2009 | Weather King 10AJA6001AH Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Air conditioner not geting cool
Jan 24, 2009 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
