Question about Samsung Televison & Video
Help diagnosing my Samsung PN51E530A3FXZA, when I power on from standby, I hear loud buzzing sound and only get a black screen nothing shows on the screen not even menu screen. Power supply?
    Top Expert:
  • Samsung Master
  • 75,311 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 19, 2016
  • 4234 Answers
SOURCE: NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
Posted on May 13, 2008
SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Posted on Nov 24, 2008
  • 124 Answers
SOURCE: Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
Posted on Feb 21, 2009
  • 534 Answers
SOURCE: Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Posted on Jun 05, 2009
SOURCE: Samsung Plasma 50" No Picture but have sound
BAD Y BOARD
Posted on Jun 08, 2009
Samsung PN51E530A3FXZA screen blank, loud buzzing from screen
Back - light inverter problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jun 25, 2016 | Samsung Series 5 51-inch PN51E530A3FXZA...
Samsung Big screen mod. HL-P6163W made load pop, then buzzing sound with screen going to black and white. Make buzzing sound and no picture when turned back on?
This set has a problem with the color wheel falling apart, which if one of the segments should fly off while the set was on it may sound like a loud pop, and the buzzing sound could be mechanical in nature with the wheel being off balance. If smoke appeared after the loud pop, then it could be a capacitor blowing in the power or video circuits. This model uses two different types of Color Wheel assemblies, either an L3 or a L6 and it would be listed on a white label on the Light Engines metal frame. Hope your solution is this easy.
Bill
Mar 08, 2011 | Samsung HL-P6163W 61" TV
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
My LG Plasma television DU-42PX12XC had a loud pop
Your tv contains protection circuitry that would shut down the tv if the ymain was out. If the ymain had blown, you'd have no sound and just a flashing standby light. My gut tells me you need to replace the Power Supply Board (PSB). I've seen this before and after spending too much money trying to diagnose a ymain failure, I was surprised to learn that when you have sound but no picture, the psb is a gonner. Try ebay, shopjimmy.com or discount-merchant.com for a replacement.
Good Luck!
Apr 20, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Burned out lamp?
First. Turn on the set and see if the Lamp Illuminates, If so then you have a bad Color Wheel. If the Lamp does not light up, you have a bad lamp.
Take out the lamp and look to the center of the lamp. If you see broken glass inside you have a bad lamp.
Apr 08, 2010 | Samsung HLR6178W 61" HDTV
No color and buzzing
sounds like a defective color wheel
Apr 05, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
