Question about Building Materials
I have an older genie opener and i bought a universal chamberlain remote.I dont think it has a learn button.what can i do
  • 244 Answers
SOURCE: need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Posted on Jan 16, 2009
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
  • 10865 Answers
SOURCE: i have a chamberlain 950-315cb
Here is the website which will provide you with all of the info you need on the chamberlain remote and door openers
Posted on May 19, 2009
SOURCE: Sears garage door opener
I just found the solution for my 'ancient' Sears garage door opener, model # 139.655000, and I figured I'd share it.
There's a separate radio module, wired to the main opener. This module is small, has a short wire/antenna, and plugs directly into an outlet.
There's a manual open/close button on this module (I didn't realize this until I got up on a ladder). This button is also a removable cover; underneath it is a "smart actuate" button -- this is your learn button.
What I did was: unplug the radio module. Pry off the cover. Plug the radio module back in. Hold down the button on the remote. Press the "smart actuate" button. This programmed my remote successfully!
Posted on Sep 21, 2009
Learn button on genie pro max garage opener is not working . How can I programm new remote?
if the learn button is truly bad you have two options either replace the circuit board or buy an external receiver. It was me a would replace the opener with a Chamberlain/Craftsman or Liftmaster belt drive opener. The new genies aren't worth a damn. I've replaced about a dozen that were a year or less old because of defects this year.
Nov 07, 2016 | Genie Pro Building Materials
My Genie door opener does not seem to want to connect to the Chamberlain remote control. Please advise!
If you have a universal remote or a max remote you can go to to check compatibility. if it is not a universal or max remote it won't work with any genie product.
May 04, 2015 | Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Want to program clicker chamberlain remote
This remote is compatible with your opener. It should of come with a manual on how to program it as well. Each opener has a different sequence to program it so I can't just give a general answer. On any opener chamberlain look for the color of the button, on a genie look to see if it has a learn button. If you need a copy of this manual you can get one at Thanks BB
Aug 15, 2010 | Chamberlain Clicker Universal Remote...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Need to match DIP switchs on a universal garage door remote
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reprogramming remotes/system
Yeh, it is called reading the manual. Push and hold LEARN or SMART button for 10 seconds, Release, Push for 1 second and enter keypad code and ENTER, Kight bulbs should blink. Hit learn again for a second and push a button on a remote. Repeat for all remotes.
Apr 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
60 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
