Question about Drills
Do you realize what a bobcat auger is!!!! It is an auger that drills post holes not a Garden tractor mower
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Drills Master
  • 102,366 Answers
Since you didn't bother to properly categrorize your earlier questions when you posted them, I've recategorized them for you.
Posted on Dec 19, 2016
I have a bobcat 15c auger! I broke the lower shaft. Is it hard to replace?
check first with a service dealer as the shafts would be difficult to break and there probably is a shear pin in the drive to prevent shaft and auger damage
if that is the case you can drive out the broken bit and tap in a new pin( available from the service dealer
Dec 19, 2016 | Drills
My 863 bobcat brush mower loses power in heavy grass. I rebuilt the pump on brush cutter. I hooked up auger and the guger turns slow like hydraulic flow is low. what should I ck.
I would flow test the pump to be sure that there are no seals that are bad or also if any of the valves in the pump are bad. If any of the valves are bad you can test the spring pressure of that valve to make sure it is within the correct specifications in accordance with the technical manual for your specific pump.
Nov 08, 2016 | Bobcat Garden
MY BOBCAT IS THROWING A ACD CODE AND QUESTION MARK CODE. IT DIES WHEN I PUT THE BLADE DOWN AND TRY TO BACK DRAG.
Jimmie, links to manuals below and codes,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TRUCK TRactor MANUALS
All Service Codes
http://www.tractorbynet.com/forums/bobcat-construction-equipment/164816-diagnostic-codes-bobcat.html
Mar 06, 2016 | Bobcat Garden
I'm looking for a manual for bobcat s130 serial number 527314309
If you are looking for a repair manual for this machine I have found a place where you can order one. I have included the link here. Bobcat S130 Repair Manual Skid Steer Loader 529211001 Download
Feb 04, 2016 | Bobcat Garden
Where can I buy a bobcat operation sensing system
Bobcat 773 Service Manual PDF ' Bobcat Service Manual
https://bobcatservicemanual.wordpress.com/.../bobcat-773-service-manu...
Apr 26, 2015 - Download your Bobcat 773 Skid Steer Loader service manual PDF (SN: 509635001-Above, 509616001-509634999). These workshop service ...
Jul 25, 2015 | Bobcat 773
Bobcat 641 skidsteer hydraulic problems.
That's one of the first things that came to mind as I was reading through your post; that the system was air-bound. Are there bleeder valves on the system?
In any event here is a website where you can buy the service manual for your skidsteer; https://mypowermanual.com/shop/bobcat/bobcat-641-642-643-skid-steer-loader-service-manual-download-6566135-10-86/
Feb 20, 2015 | Bobcat Garden
PTo will spin post hole digger but three point
If the ground is extremely hard. more weight may be required. A small amount of vegetation on the cutting surface of the auger will stop it from digging.
Oct 05, 2014 | Garden
My mower dies after 30 mins of mowing. The filters are new and clean.
I had a similar problem. Please post back if this works.
As soon as the mower begins to stall, immediately loosen the gasoline cap. If the mower runs properly, the small vent holes on the gas cap must be drilled out, deposits have built up in the vents.
Gary
Mar 04, 2011 | Craftsman Garden
Nedd manual for bobcat/ransome T3100
Ask here, they will find every Bobcat manual
Oct 20, 2009 | Garden
Drills Logo
55 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
