Question about Tablets & eReaders
My touch screen WOnt work it selects an inch or two away from my finger sometimes it'll let me push and drag to an option to select Intel ematic ewt826bk 8
  • Andres Nieves Jr.
    Andres Nieves Jr. Jul 25, 2017
    Try these drivers from the Intel website. They worked perfect for my daughter's Ematic.https://downloadcenter.intel.com/downloa...
    Loyalty:
    Visited the website for 30 consecutive days.
  • Tablets & eR... Master
  • 936 Answers
Hi sounds like u need a new touch screen digitizer ...,.ring 866-925-2350..... Good luck
Posted on Dec 19, 2016
3 Suggested Answers
Ngoro
  • 1144 Answers
SOURCE: users manual for ematic 8 inch tablet
http://www.ematic.us/sites/default/files/EWT816_manual.pdf
Posted on Apr 10, 2015
Terry Corrow
  • 10875 Answers
SOURCE: Where is the imei number on my EGQ347 EMATIC 7 INCH SCREEN 8 GBPINK TABLET ?
inside or in about,in settings
Posted on Jul 23, 2015
My ematic 7 inch quad-core tablet wont turn on or charge
Either your charger is fubar or your batteries can no longer take a charge.
Oct 12, 2016 | Ematic 7" Touch Screen Tablet
How to delete extra pages
    1. Remove Home Screen Panel
      1. From a home screen, pinch in on the screen. Place two fingers on the screen and bring them together.
      2. Select and hold the appropriate panel then drag it to Remove (located at the top).
      Add/Remove Home Screen Panels - Samsung Galaxy Tab 2 ...
      www.verizonwireless.com/support/knowledge-base-63229/ Verizon Wireless
    Feedback
  1. How to Manage Home Screen Pages on the Android Tablet ...
    www.dummies.com/.../how-to-manage-home-screen-pages-on-the-andro...
    To edit Home screen pages, pinch the Home screen: Touch the screen with two fingers and drag them together. You can then manage Home screen pages. Generally speaking, to rearrange the pages, long-press and drag it to a new spot. When you're done, touch the Back or Home icon.
    www.verizonwireless.com/.../knowledge-base-63229/
    Verizon Wireless
Jan 09, 2016 | Tablets & eReaders
EMATIC EWT935DK Touch Screen doesn't work.
sometimes the screen just glitches on any device that has touch screen if there is no reset pinhole on the device anywhere you may try to hold power and volume up until it restarts sometimes that can solve the problem I have to so this to my Galaxy S4 Active sometimes
Nov 04, 2015 | Tablets & eReaders
When I turn on my tablet my screen is frozen all it does is go from ematic screen on start up to android is upgrading over starting apps. back and forth and thats all it does please help?
if you can try and save your photo's etc from it..then close it down. now hold the home button and the volume up button together and turn it on while holding them buttons. you will get a screen to restore it and other options
Apr 24, 2015 | Ematic 7" Tablet Computer
What do we do it is saying rstech_teni has stopped
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the A727 manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attemps.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
Dec 25, 2014 | Ematic 7" Touch Screen Tablet
How do i open my Ematic FTABMB2 4.3-Inch 4GB Fun Tab Mini Touch Screen Kids Tablet
You need special tools to crack open the case. You may get lucky with a thin guitar pic.
Jul 04, 2014 | Ematic FTABMB2 4.3" Fun Tab Mini Pro...
I have the Sharper Image m18a android tablet and everytime i touch the screen there comes some blue cross that draws a short line and there are some columns in the top of the screen conected to that i
In my tablet, in settings, under 'Developer Options' in 'User Interface' there is 'Pointer Location' which is a screen overlay which shows current touch data. To me what you are seeing sounds exactly like this function when it is selected. Hope this is the answer you need.
Jan 14, 2013 | Nextbook Tablets & eReaders
I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
Jan 08, 2013 | Supersonic 7" Touch Screen MID Tablet
Tablets & eReaders Logo
73 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
