Question about Dryers
My dryer says replace filter after I have replaced it
  • 575 Answers
Reset it by unplugging it.
Posted on Dec 19, 2016
I own a dryer model #HLP140E and I need to buy a replacement filter that fits inside the unit. Please direct me to wear I can buy replacements. Thanks!
eBay:
http://shop.ebay.com/i.html?_nkw=+Dryer+filter&_sacat=0&_odkw=Haier+Electric+Portable+Dryer+filter&_osacat=0&_trksid=p3286.c0.m270.l1313
repairclinic:
http://www.repairclinic.com/Haier-Dryer-Filter-Parts
May 22, 2011 | Haier HLP140E Electric Portable Dryer
Gasket for dryer lit catcher is coming off
The gasket on the lint filter is not very important, but you can get a replacement lint filter. There is a screw at the center bottom area of the lint filter area which can catch on the gasket. If you replace it with a shorter screw or remove it, grind it down a bit, and replace it you will help avoid a repeat condition.
Jan 02, 2011 | LG D2526 Gas Dryer
How to replace the belt
Try this link Dryer belt replacement video or if your lint filter is in the door try this link Dryer belt replacement video
Nov 01, 2010 | Kenmore 73952 Gas Dryer
I need to replace fuse where
it's on the blower wheel housing,if the lint filter is on top of dryer it's in the back,if filter is inside then it's in the front,send model number next time,also if the thermal fuse is bad you need to clean out the dryer or it will pop again,clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line
Jan 24, 2010 | Kenmore Dryers
Need to replace the Air Compressor on my 2002 Sant FE. Hyundai Dealer recommended "only" the compressor needed to be replace. Although I am not an expert on air conditioning, this made me skeptical...
Just let the dealer replace the dryer/filter. Its a very cheap part. The only time it needs to be replaced is if there is a mechanical copressor failure. I recomend changing filter/dryer . Also orings on both dryer/filter and compressor. It won't hurt to just replace comressor though and see if this fixes.
Apr 10, 2009 | 2002 Hyundai Santa Fe
Lint filter not blocking lint
Make sure it isn't bent or has any holes in it and is sealing around the edges. If not, replace it .
Mar 19, 2009 | GE DCVH515EFWW Electric Dryer
Noise from the lint vent
idf top mount filter remove screws under filter lid remove nback cover remove 4 screws holding cover and lint housing to back pull housing down and out ..something may be hitting wheel just clean and reassemble ..on inside door filter remove bottom cove remove filter remove screws holding filter/blower cover in place ckd for smae objects clean and reassemble
Sep 02, 2008 | Kenmore 63012 Electric Dryer
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Won't heat up
Try removing the lint filter from the dryer and with no clothes, start the the dryer, and if it works then replace your lint filter.
Tip: Fabric softener sheets in the dryer can deposit an invisible coating on the screen of the filter and reduce air flow.
May 27, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
