Question about Kenmore Washing Machines
For a Kenmore HE2 plus washer, model 110.4751. The water is draining very slowly from the tray holder area, so it splls out. I disconnected the hose and it is not plugged. Where do I look from here.
  • Mike Miller
    Mike Miller Dec 19, 2016
    Found the problem. It was a sock stuck between the drain opening and the drum. As I saw on a posting, I peeled back the seal and there it was.
SOURCE: My Kenmore HE2 Plus Front Load washer won't drain...
We have the exact same washing machine, and the same problem. we will need to lift the front of your washer up and undo the bolts to the front cover. you will see a white round turn nob, this is the filter unscrew it (you kight plug your nose) and empty all contents, replace, screw the front plate back on and you are good to go!
Hope this helps, i wish someone would of helped us!!
good luck
Posted on Jan 31, 2009
  • 188 Answers
SOURCE: he2 front loading washing machine leak at the soap dispenser regi
Hi dlypooh, thought I would post the solution here as well for anybody who needs to do a search in the future...
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly (re: dlypooh), open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Posted on Feb 21, 2009
  • 220 Answers
SOURCE: f21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Posted on Sep 03, 2009
  • 6 Answers
SOURCE: My Kenmore HE2 Plus Front Load Washer won't drain?
remove front panel at bottom, get a bucket & clean pump out
Posted on Nov 10, 2009
kvhappliance
  • 218 Answers
SOURCE: Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Posted on Mar 22, 2010
Washer not draining
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Nov 20, 2012 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE2 Plus wont start and it gives code F-21...... the door locks but the washer wont fill up with water.. then it faults out. What can I do?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
Water pump to drain water activates but doesn't drain water from machine
Hi, Make the following check: 1. Unplug washer or disconnect power. 2. Check wire harness connections. 3. Check drain pump. 4. Check drain pump motor. 5. Check that the drain hose and drain pump filter are clear of foreign objects. 6. Plug in washer or reconnect power. 7. Verify CCU operation by running a Diagnostic Test or any cycle.
Apr 11, 2010 | Kenmore HE2 Plus Front Load Washer
Water is coming out of the area were you put the detergent. Hoses are all connected and seam to be in good condition.
I take it his is a frontload style washer. You probably have soap buildup underneath the detergent tray, where the soapy water enters the hose that goes to the tub. Try to remove the soap tray and clean the buildup.
Jan 12, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore front load he2 plus wont drain.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Aug 05, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Error Code: F-20
You probably have this solved by now but for others who read this as I did.............
F-20 means
“F20” on display
(Water Inlet Problem—no water or insufficient
Hope this helps everyone else as it did me, thanks
Oct 24, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My kenmore he2 plus washer is showing f21
"F21" is a Long Drain error. This occurs when the drain time exceeds 8 minutes. You will need to remove the bottom panel under the door by removing the two screws at the bottom edge of the panel. First, check the electrical connections to the drain pump and make sure the pump is running. Check the drain pump filter to make sure it is not clogged with debris. This is a very common problem. HINT: Before removing the drain pump filter, pull the drain hoses from the standpipe at the wall and use a shop vac to pull a vacuum on the drain hose to get rid of all residual water from the pump and drain lines. This is also a good way to get rid of minor clogs. If you do not own a shop vac, be prepared to lay down some old towels and soak up some water. There's quite a bit of residual water in the wash tub and lines (this is normal). In addition, check your drain hoses to make sure they are not clogged or kinked. If you check everything and still have the error code, replace the drain pump. Replacement parts can be found at searspartsdirect.com and repairclinic.com. Just type in your model number in the search menu. I hope this helps you. If you require further assistance, please let me know.
Aug 16, 2008 | Washing Machines
Washing Machines Logo
46 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
